ObjectARX
Why do the RealDWG docs say that some functions are not applicable "Due to the graphics dependency of the AcDbSubentId"?
3 REPLIES 3
tbrammer
318 Views, 3 Replies
The ObjectARX docs state this for various functions that use AcDbSubentId:
"Due to the graphics dependency of the AcDbSubentId object, this function is not applicable for the RealDWG SDK."
I.e. for:
  • AcDb3dSolid::filletEdges(const AcArray<AcDbSubentId *> & edgeSubentIds,...)
  • AcDb3dSolid::setSubentColor(const AcDbSubentId & subentId, const AcCmColor & color)
I tried the code below with RealDWG and it worked perfectly. It creates an AcDb3dSolid box, recolors faces and edges and creates a fillet for the edges around one face.
Could it be that this statement is outdated? Or are there really any restrictions regarding AcDbSubentId in RealDWG? I can't see any reason for that. in my test the AcDbSubentIds had unique Adesk::GsMarkers. So, they should work perfectly to identify subentities.
void cmdTestBrep()
	Acad::ErrorStatus es;
	AcDbDatabase *db = new AcDbDatabase();
	AcDb3dSolid *solid = new AcDb3dSolid;
	solid->setDatabaseDefaults(db);
	es = solid->createBox(200.0, 300.0, 400.0);
	AcDbObjectId idSolid;
	es = PostToDb(db, idSolid, solid);
	AcBrBrep *pBrep = new AcBrBrep();
	AcDbFullSubentPath adfsp(idSolid, kNullSubentId);
	AcBr::ErrorStatus ebs = pBrep->setSubentPath(adfsp);
	AcBrBrepFaceTraverser faceTraverser;
	ebs = faceTraverser.setBrep(*pBrep);
	assert(ebs == AcBr::eOk);
	std::vector<Face2Edges> facePathToEdgePaths;
	AcBrFace face;
	AcDbFullSubentPath subFacePath, subEdgePath;
	for (ebs = faceTraverser.restart(); !faceTraverser.done(); ebs = faceTraverser.next())
		ebs = faceTraverser.getFace(face);
		if (ebs == AcBr::eOk)
			ebs = face.getSubentPath(subFacePath);
				Face2Edges f2es;
				f2es.face = subFacePath;
				AcBrFaceLoopTraverser faceLoopTrav;
				ebs = faceLoopTrav.setFace(face);
				for (; !faceLoopTrav.done(); ebs = faceLoopTrav.next())
					AcBrLoop loop;
					ebs = faceLoopTrav.getLoop(loop);
						AcBrLoopEdgeTraverser loopEdgeTrav;
						ebs = loopEdgeTrav.setLoop(loop);
						for (; !loopEdgeTrav.done(); ebs = loopEdgeTrav.next())
							AcBrEdge edge;
							ebs = loopEdgeTrav.getEdge(edge);
								ebs = edge.getSubentPath(subEdgePath);
									f2es.edges.append(subEdgePath);
				facePathToEdgePaths.push_back(std::move(f2es));
	delete pBrep;
	// recolor the faces
	if ((es = acdbOpenObject(solid, idSolid, AcDb::kForWrite)) == Acad::eOk)
		AcCmColor color;
		Adesk::UInt16 colorIndex = 0;
		for (const Face2Edges & f2es : facePathToEdgePaths)
			color.setColorIndex(++colorIndex);
			es = solid->setSubentColor(f2es.face.subentId(), color);
		static double dRadius = 10.0;
		static double dSetbackStart = 0.0;
		static double dSetbackEnd = 0.0;
		for (const Face2Edges& f2es : facePathToEdgePaths)
			int count = f2es.edges.length();
			if (count>0)
				AcArray<AcDbSubentId> edgeIds;
				AcArray<AcDbSubentId*> edgeIdPtrs;
				AcGeDoubleArray startSetback, endSetback, radius;
				edgeIds.setLogicalLength(count);
				edgeIdPtrs.setLogicalLength(count);
				radius.setLogicalLength(count);
				startSetback.setLogicalLength(count);
				endSetback.setLogicalLength(count);
				for (int i=0; i<count; ++i)
					es = solid->setSubentColor(f2es.edges[i].subentId(), color);
					const AcDbFullSubentPath& path = f2es.edges[i];
					edgeIds[i] = path.subentId();
					edgeIdPtrs[i] = &(edgeIds[i]);
					radius[i] = dRadius;
					startSetback[i] = dSetbackStart;
					endSetback[i] = dSetbackEnd;
				es = solid->filletEdges(edgeIdPtrs, radius, startSetback, endSetback);
				break;
		solid->close();
	db->saveAs(L"c:\\temp\\brep.dwg");
	delete db;
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
3 REPLIES 3
m_latz
in reply to: tbrammer
I would agree with you that not everything that is written in the documentary of RealDWG is always correct.
But have you tested your example on a computer that really only has the "runtime environment", not the "developer environment" of RealDWG installed and no other autodesk products ?
regards
Markus
tbrammer
I don't think that my RealDWG app would use any modules from an existing AutoCAD installation and invoke it's GS functions.  Anyway, I ran my test app together with "Process Monitor" snooping for access to paths beginning with "C:\Program Files\Autodesk\AutoCAD". It didn't find any. All accesses have been made to paths starting with "C:\Program Files\Autodesk\RealDWG".
In the meantime I asked this directely to the ADN DevSup. Let's see what they respond.
tbrammer
I asked this question to the Autodesk Developer Support.
They confirmed that the statement is obsolete. These function can be used in RealDWG.
”Boost
