What directories readDwgFile chech?
Where can (or should) be dwg file if i
want read it like that:
AcDbDatabase *pDb = new
AcDbDatabase(Adesk::
color=#a000a0>kFalse
if ((es = pDb->
color=#880000>readDwgFile
("BLOCK.DWG")) !=
color=#0000ff>Acad
::eOk){
    delete pDb;
    return es;
AutoCAD searches on  the
given support pathes,
in Acad Options->Files
Bernd
AcDbDatabase *pDb =
color=#a000a0>new
AcDbDatabase(
color=#0000ff>Adesk
::kFalse);
if ((es = pDb->
("BLOCK.DWG")) !=
color=#0000ff>Acad
::eOk){
    delete pDb;
    return es;
It doesn't load unless i copy it to "autodesk map
5" directory 😞
In support file search path there a lot others
paths but it didn't work if i copy my dwg there.
Bernd
i want read it like that:
AcDbDatabase *pDb =
color=#a000a0>new
AcDbDatabase(
color=#0000ff>Adesk
::kFalse);
if ((es = pDb->
("BLOCK.DWG")) !=
color=#0000ff>Acad
::eOk){
    delete pDb;
    return es;
AcDbDatabase::readDwgFile() expects the filename
argument to be a full path.  It does not search along any search paths to
find the file.  You should use AcDbHostApplicationServices::findFile() to
find the file and get a full path before calling readDwgFile().
AcDbDatabase *pDb =
color=#a000a0>new
AcDbDatabase(
color=#0000ff>Adesk
::kFalse);
if ((es = pDb->
("BLOCK.DWG")) !=
color=#0000ff>Acad
::eOk){
    delete pDb;
    return es;
