Viewport Specific geometry
Hi all,
I want to draw a viewport specific entity using AcGiViewportGeometry object. How could I display my custom entity only on the active viewport when I have more than one viewports in model space?       For example, I want to draw a polygon int the first viewport and  a circle in the second one.
Any help would be greatly appreciated
tbrammer
If you have a custom entity, you can write your own virtual method:
void myEntity::subViewportDraw(AcGiViewportDraw* mode)
AcGiViewport &vp = mode->viewport(); Adesk::ULongPtr id = vp.viewportId();
AcGePoint2d lower_left, upper_right;
vp.getViewportDcCorners(lower_left, upper_right);
// Do your VP specific drawing depending on id or DC corners }
subViewportDraw() will only be called, if your  myEntity::subWorldDraw(AcGiWorldDraw* mode)  returns  Adesk::kFalse.
Cheers
--Thomas
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
