Announcements
Update Viewport after enabling an VisibilityOverrule
fehrsZBFB9
fehrsZBFB9
Hi Folks,
I have implemented an VisibilityOverrule which temporarily hides all entities of a drawing.
After it is enabled I us a jig class to interact with the user inside the cleared drawing. For all visual styles except wireframe2d, the entities are not hidden automatically. I have to refesh the viewport. The only way I found so far is to call the undocumented function acedColorSettingsChanged. After it is called. All entities are gone.  I tried different ways to achieve the same result but without success.
I tried:
acedCommandS(RTSTR, L"REGEN", RTNONE)
acedCommandS(RTSTR, L"REGENALL", RTNONE)
acedUpdateDisplay
acedUpdate
AcGsView::invalidate()
AcGsView::update()
What else could it be? Any ideas?
Martin
Alexander.Rivilis
Try:
acedCommandS(RTSTR, L"REGEN3", RTNONE);
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
fehrsZBFB9
It works so far. Sadly it does not regenerate the hidden entities for wireframe2d after the overrule gets disabled. They are still hidden afterwards. For wireframe2d I have to use REGEN instead.
Which is the fastest/simplest way to detect if wireframe2d is active?
Alexander.Rivilis
AcDbObjectPointer<AcDbVisualStyle> pVstyle(acdbGetViewportVisualStyle(), AcDb::kForRead);
if (pVstyle.openStatus() == Acad::eOk)
    acutPrintf(L"\nVisual Style is %s WireFrame 2D",
      (pVstyle->type() != AcGiVisualStyle::k2DWireframe) ? L"NOT" : L"");
Expert Elite Member
