Hi Folks,
I have implemented an VisibilityOverrule which temporarily hides all entities of a drawing.
After it is enabled I us a jig class to interact with the user inside the cleared drawing. For all visual styles except wireframe2d, the entities are not hidden automatically. I have to refesh the viewport. The only way I found so far is to call the undocumented function acedColorSettingsChanged. After it is called. All entities are gone. I tried different ways to achieve the same result but without success.
I tried:
acedCommandS(RTSTR, L"REGEN", RTNONE)
acedCommandS(RTSTR, L"REGENALL", RTNONE)
acedUpdateDisplay
acedUpdate
AcGsView::invalidate()
AcGsView::update()
What else could it be? Any ideas?
Martin
Solved by Alexander.Rivilis. Go to Solution.
Try:
acedCommandS(RTSTR, L"REGEN3", RTNONE);
Facebook | Twitter | LinkedIn
It works so far. Sadly it does not regenerate the hidden entities for wireframe2d after the overrule gets disabled. They are still hidden afterwards. For wireframe2d I have to use REGEN instead.
Which is the fastest/simplest way to detect if wireframe2d is active?
AcDbObjectPointer<AcDbVisualStyle> pVstyle(acdbGetViewportVisualStyle(), AcDb::kForRead); if (pVstyle.openStatus() == Acad::eOk) { acutPrintf(L"\nVisual Style is %s WireFrame 2D", (pVstyle->type() != AcGiVisualStyle::k2DWireframe) ? L"NOT" : L""); }
