Unable to explode non-uniformly scaled block reference
I'm facing an issue when trying to explode an AcDbBlockReference object programmatically after applying a non-uniform scale. The block contains multiple polylines on different layers, and the goal is to scale the block along the X-axis, explode it, and then reconstruct the polylines based on their layers.
However, after applying non-uniform scaling (using the setScaleFactors(const AcGeScale3d&) on the block reference), the explode() method does not work as expected. Specifically:
- The explode() method returns an empty AcDbVoidPtrArray, indicating that no entities were found.
- There are no errors during the explosion process, but the result is empty.
- Manual explosion of the block in AutoCAD works correctly after the scale transformation.
- Explode works normally if uniform scaling.
Any insights or advice on how to resolve this would be greatly appreciated!
