ObjectARX
The MLeader object I created does not have an arrow
2 REPLIES 2
zhengyunyang2019
230 Views, 2 Replies
I created a block reference, established a AcDbMLeaderStyle, and then created an MLeader based on this style with the content being a block. However, it doesn't display an arrow.
This is the code for creating an AcDbMLeaderStyle.
void InitMleaderStyle()
  AcDbMLeaderStyle* pMleaderStyle = new AcDbMLeaderStyle();
  pMleaderStyle->setName(mLeaderStyleName);
  pMleaderStyle->setContentType(AcDbMLeaderStyle::ContentType::kBlockContent);
  pMleaderStyle->setBlockConnectionType(AcDbMLeaderStyle::BlockConnectionType::kConnectBase);
  pMleaderStyle->setArrowSize(2.0);
  pMleaderStyle->setAnnotative(false);
  pMleaderStyle->setLeaderLineType(AcDbMLeaderStyle::LeaderType::kStraightLeader);
  AcDbObjectId mNWHMLeaderStyleId;
  Acad::ErrorStatus es = pMleaderStyle->postMLeaderStyleToDb(acdbCurDwg(), mLeaderStyleName, mNWHMLeaderStyleId);
  if (es != ErrorStatus::eOk && es != ErrorStatus::eDuplicateKey)
    acedAlert(L"\nERROR。");
  pMleaderStyle->close();
This is the code for creating an MLeader.
AcDbObjectId oBlock;
CreateTextTriangle(oBlock);
AcDbObjectId oTextStyleId;
GetMleaderStyle(oTextStyleId);
opEntity = new AcDbMLeader();
opEntity->setMLeaderStyle(textStyleId);
opEntity->setBlockContentId(oBlock);
int leaderIndex;
opEntity->addLeader(leaderIndex);
opEntity->addLeaderLine(iPoint, leaderIndex);
opEntity->addFirstVertex(leaderIndex, iPoint);
opEntity->setFirstVertex(leaderIndex, iPoint);
AcGePoint3d ENDPoint(iPoint);
secPoint.x += 5;
secPoint.y -= 2;
opEntity->setLastVertex(leaderIndex, ENDPoint);
AcDbBlockTable *pBlockTable;
Acad::ErrorStatus resBlockT = acdbCurDwg()->getSymbolTable(pBlockTable, AcDb::kForWrite);
if ( Acad::eOk != resBlockT)
  acedAlert(L"\nERROR");
  return ;
AcDbBlockTableRecord* pModelSpace;
Acad::ErrorStatus resGetAt = pBlockTable->getAt(ACDB_MODEL_SPACE,pModelSpace, AcDb::kForWrite);
if (Acad::eOk != resGetAt)
  pBlockTable->close();
  return ;
if (pModelSpace->appendAcDbEntity(oEntityId, opEntity) != Acad::eOk)
opEntity->close();
pModelSpace->close();
2 REPLIES 2
ynapeu
in reply to: zhengyunyang2019
Hello
i think you should use
 opEntity->addLeader(&leaderIndex);
tbrammer
I think it should be like this:
//opEntity->addFirstVertex(leaderIndex, iPoint);
opEntity->addLastVertex(leaderIndex, ENDPoint);
Also you should use the method
es = pMLeader->postMLeaderToDb(pDB);
to post the leader to the database.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
”Boost
