ObjectARX
Simple (!?) Polyline Jig
4 REPLIES 4
Kyudos
1111 Views, 4 Replies
I'm trying to replicate the default ACAD polyline jig with the dynamic angle and aligned dimensions for my AcDbPolyline-derived custom objects using ObjectArx (C++). All the example of polyline jigs I can find are in C# - I've tried converting several but I'm not getting good results.
The basic documentation on jigging is pretty sparse and for adding dynamic dimensions practically non-existent.
Does anyone have a straightforward example of jigging with dynamic dimensions in C++?
Cheers
4 REPLIES 4
Alexander.Rivilis
in reply to: Kyudos
ObjectARX SDK 2008 has a sample Grip wich use dynamic dimensions. I've adopted this sample to ObjectARX 2017 and tried to attach it to this post, but has a problem. So there is a direct link: http://adn-cis.org/assets/gallery/AutoCAD/grip.zip
Build solution, load it to AutoCAD and run command RECTJIG.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Kyudos
in reply to: Alexander.Rivilis
Thanks Alexander - this looks like just the ticket 🙂
Can't link to "acdb22d.lib".How to solve it?
Link with acdb22.lib
Expert Elite Member
Autodesk Customer Advisory Groups
