ObjectARX
Simple Associative Dimension
18 REPLIES 18
Message 1 of 19
EMD1954
742 Views, 18 Replies
Does anyone have a sample of how to create an associative dimension between two points?
Ed
18 REPLIES 18
Message 2 of 19
EMD1954
in reply to: EMD1954
Sorry, forgot to add that this is a simple, linear dimension.
Message 3 of 19
Alexander.Rivilis
Maybe this sample can help you: https://adndevblog.typepad.com/autocad/2015/03/creating-associative-dimension-in-paperspace-associat...
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 4 of 19
EMD1954
I want to do it in model space, not paper space.  Not sure this is appropriate?
Message 5 of 19
Alexander.Rivilis
The same in model space. I think you have to do minimum changes in this code.
Expert Elite Member
Message 6 of 19
EMD1954
in reply to: Alexander.Rivilis
Okay, thanks.  I'll let you know how it works for me.
Message 7 of 19
EMD1954
Alexander,
The file "Results.pdf" show the results when I call "paperRotatedDimAssoc()", and "__Temp.TXT" (my .cpp file) is my code.  Any suggestions?
Message 8 of 19
Alexander.Rivilis
Maybe you have to change dimension properties (or dimension style)
Expert Elite Member
Message 9 of 19
EMD1954
I set all of the appropriate system variables and only got slight improvement.  Then I tried the old-fashioned way:
int es = acedCommandS(RTSTR, _T("_DIMENSION"), RTSTR, _T("0.0,0.0"), RTSTR, _T("0.0,240.0"), RTSTR, _T("0.0,0.0"), RTSTR, _T(""), RTNONE);
It returns -5001.
Message 10 of 19
Alexander.Rivilis
You can set dimension style to dimension with this code:
dim->setDatabaseDefaults();
dim->setDimstyleData(pCurDb->dimstyle());
Expert Elite Member
Message 11 of 19
EMD1954
Yes, I had both of those.  Do you see what's wrong with my acedCommansS()?  Any idea why it doesn't work?
Message 12 of 19
Alexander.Rivilis
Context of document or application? Also you can set CMDECHO to 1 in order to see in commandline what wrong.
Expert Elite Member
Message 13 of 19
EMD1954
Here's the command line:
Dim: 0.0,0.0
Dim: 0.0,240.0
Dim: 0.0,0.0
Dim:
Type EXIT to return to COMMAND prompt.
If I add _T("EXIT") instead of _T("") like this:
 int es = acedCommandS(RTSTR, _T("_DIM"), RTSTR, _T("0.0,0.0"), RTSTR, _T("0.0,240.0"), RTSTR, _T("0.0,0.0"), RTSTR, _T("EXIT"), RTNONE);)
Dim: 0.0,0.0
Dim: 0.0,240.0
Dim: 0.0,0.0
with es = 5100
Dim: EXIT
Message 14 of 19
EMD1954
Alexander,
I tried this, with the same results:
struct resbuf *cmdlist;
cmdlist = acutBuildList(RTSTR, _T("DIM"), RTSTR, _T("0.0,0.0"), RTSTR, _T("0.0,240.0"), RTSTR, _T("0.0,0.0"), RTSTR, _T("EXIT"), RTNONE);
if (cmdlist == NULL) acdbFail(_T("Couldn't create list\n"));
acedCmdS(cmdlist);
acutRelRb(cmdlist);
Dim: 0.0,0.0
Dim: 0.0,240.0
Dim: 0.0,0.0
Dim: EXIT
I'm lost.
Message 15 of 19
EMD1954
Finally, after too many hours, I think I worked out all of the bugs.  This seems to work just fine in case anyone else was looking for this:
//------ FUNCTION makeRotatedDim() ------//
void makeRotatedDim(AcGePoint3d pt1, AcGePoint3d pt2, double dAngle)
Acad::ErrorStatus es;
AcGePoint3d ptMid = getMidPoint(pt1, pt2);  // getMidPoint is one of my simple utilities
AcDbBlockTableRecord* blkRec;
AcDbDatabase *pCurDb;
pCurDb = acdbHostApplicationServices()->workingDatabase();
AcDbRotatedDimension* dim = new AcDbRotatedDimension;
dim->setXLine1Point(pt1);
dim->setXLine2Point(pt2);
dim->setRotation(dAngle);
dim->setHorizontalRotation(dAngle);
dim->useDefaultTextPosition();
es = acdbOpenObject(blkRec, pCurDb->currentSpaceId(), AcDb::kForWrite);
acedAlert(acadErrorStatusText(es));
es = blkRec->appendAcDbEntity(dim);
if(es!=Acad::eOk) acutPrintf(_T("\nError adding entity (%d)"), es);
blkRec->close();
dim->close();
return;
} // end of function makeRotatedDim()
Message 16 of 19
Alexander.Rivilis
This dimension is not associative. In order to create associative dimension you have to use code from link I've posted above.
Expert Elite Member
Message 17 of 19
EMD1954
Alexander,
All I know is that when I stretch it, the dimension text changes properly, so it does everything I needed it to do.
Ed
Message 18 of 19
Alexander.Rivilis
@EMD1954 wrote:
Alexander,
Ed
About associative dimensions:
Dimensions can be associative, which mean that they adjust to changes in the geometric objects that they measure.
Dimension associativity defines the relationship between geometric objects and the dimensions that give their distance and angles.
https://help.autodesk.com/view/ACD/2023/ENU/?guid=GUID-8B7E8C96-C30D-409E-881E-7942871E80DA
Expert Elite Member
Message 19 of 19
EMD1954
Sorry for the mistake in nomenclature.  I just needed a dimension object that hit the correct points, had the correct text and changes when I stretch it.  I'm good and will close this thread.
Ed
”Boost
