Problem with AcArray
Kyudos
Advisor Advisor
Kyudos
At the end of one of my functions, my code is throwing a heap exception when doing a 'RemoveAll' on an AcArray<int>.
The array is declared at the start of the function.
Can I assume this is not really a problem with AcArray? Something else is causing it?
Kyudos
Yeah - it was caused elsewhere!
As far as i know, AcArray uses acdbAlloc/acdbFree for memory management.
If you want to use default malloc/free for your library.
You can explicitly allocate physical buffer for AcArray types to avoid this
e.g.)
  AcArray<AcGePoint3d> output;
  output.setPhysicalLength(<enough_size>);
  entity->some_function(output);
If you don't know how much buffer to be required, then you should explicitly deallocate with it
Here is some of my template code for deallocation
// Explicit AcArray memory buffer deallocation
template<typename T>
void MyAcArrayFree(AcArray<T>& buffer)
    // Only if allocated with ::acdbAlloc
    if (0 == buffer.physicalLength())
    return;
    // AcArray transparent structure
    struct AcArrayView
        T* mpArray;
        int mPhysicalLen; // Actual buffer length.
        int mLogicalLen; // Number of items in the array.
        int mGrowLen; // Buffer grows by this value.
    static_assert(sizeof(AcArray<T>) == sizeof(AcArrayView));
    // Force cast to AcArray transparent structure
    auto pArrayView = reinterpret_cast<AcArrayView*>(std::addressof(buffer));
    // Call dtor data type T has destructor
    if constexpr (std::is_destructible_v<T>)
        for (size_t i = 0; i < pArrayView->mLogicalLen; ++i)
            (pArrayView->mpArray + i)->~T();
    // Explicitly deallocate buffer
    ::acdbFree(pArrayView->mpArray);
    // Reset to Zero
    pArrayView->mpArray = nullptr;
    pArrayView->mPhysicalLen = 0;
    pArrayView->mLogicalLen = 0;
