ObjectARX
Picking Point
5 REPLIES 5
johnteng00
465 Views, 5 Replies
Picking Point
Hi guys,
I develop addin based objectarx, c++ codes. I ask user to pick a entity like line or edge in the solid model, but I need to have the picking point in the 3D model space. How can I get the picking point on the selected entity? Is it possible to get user's picking point?
Regards
John
5 REPLIES 5
johnteng00
in reply to: johnteng00
Hi guys,
If any experts from AutoDesk see this post, could you please reply to this question? whether it is possible or not to get the picking point from the user?
Thank you very much.
Regards
John
norman.yuan
you would use acedEntSel()/acedNEntSel()/acedNEntSelP() method. If user picks an entity,  the result not only includes the selected entity, but also the exact point user clicked (which may or may not falls on the entity selected, depending on the pick box's size).
Norman Yuan
Drive CAD With Code
daniel_cadext
That said, I believe the point returned acedEntSel is UCS. (just a FYI)
You can try using AcDbAssocPersSubentIdPE and iterate edges to map out the closest point on the closest edge to the pick point
Example (C++20)
static auto entsel()
    AcDbObjectId id;
    AcGePoint3d pnt;
    ads_name name = { 0L };
    int res = acedEntSel(L"\nSelect it: ", name, asDblArray(pnt));
    if (auto es = acdbGetObjectId(id, name); es != eOk)
        return std::make_tuple(Acad::PromptStatus::eError, id, pnt);
    return std::make_tuple(Acad::PromptStatus(res), id, pnt);
static std::unique_ptr<AcGeCurve3d> getGeCurve(const AcDbCurve& pDbDurve, Acad::ErrorStatus &es)
    AcGeCurve3d* pCurve = nullptr;
    es = pDbDurve.getAcGeCurve(pCurve);
    return std::unique_ptr<AcGeCurve3d>(pCurve);
static void AcRxPyApp_idoit(void)
    Acad::ErrorStatus es = eOk;
    auto [ps, id, pnt] = entsel();
    if (ps == Acad::PromptStatus::eNormal)
        AcDbEntityPointer pEntity(id);
        auto* pe = AcDbAssocPersSubentIdPE::cast(pEntity->queryX(AcDbAssocPersSubentIdPE::desc()));
        AcArray <AcDbSubentId> edgeIds;
        es = pe->getAllSubentities(pEntity,AcDb::kEdgeSubentType,edgeIds);
        for (int i = 0; i < edgeIds.length(); ++i)
            AcDbFullSubentPath path(id, edgeIds[i]);
            std::unique_ptr<AcDbEntity> pSubEntity(pEntity->subentPtr(path));
            if (pSubEntity != NULL)
                if (pSubEntity->isA()->isDerivedFrom(AcDbCurve::desc()))
                    AcDbCurve* pDbCurve = static_cast<AcDbCurve*>(pSubEntity.get());
                    if (auto curve = getGeCurve(*pDbCurve, es); es == eOk)
                        acedGrDraw(asDblArray(pnt), asDblArray(curve->closestPointTo(pnt)), 1, 0);
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
tbrammer
in reply to: norman.yuan
According to my experience the pickpoint returned from acedEntSel()/acedNEntSel()/acedNEntSelP() is the point in UCS that AutoCAD displays in the coordinates window on the status line in the moment of selection.
This point will usually have Z=0. If you pick a 3DSOLID at a 3D point that is not within the current UCS plane you won't get the expected result but a projection of the pickpoint to the UCS plane along the line of sight.
I know only these two ways to retrieve the correct 3D pickpoint:
  1. Use acedSSGet(L"_:S", NULL, NULL, NULL, sset) to do the selection.
    Than acedSSNameX(&rb, sset, 0) will give you the 3D WCS pickpoint in the resbuf *rb list:
    [0] list-begin
    [1] 1 rint
    [2] 1504745003488-1504771237483 rlname
    [3] 50 rint
    [4] list-begin
    [5] 0 rint
    [6] 2520.16553,3274.38672,119.046524            <---- 3D pickpoint in WCS
    [7] -0.577350259,0.577350259,-0.577350259
    [8] list-end
    [9] list-end
  2. Derive a class MyInputPointMonitor from AcEdInputPointMonitor, implement
    MyInputPointMonitor::monitorInputPoint(const AcEdInputPoint& input, AcEdInputPointMonitorResult& output)
    and store input.computedPoint() for the selected point.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
john4TMYX
in reply to: tbrammer
Hi Thomas,
Thank you very much. You are right. It works. Appreciated your help!
Regards
John
AutoCAD Inside the Factory
