Open DWG with ARX in MDI
sandip.chaudhari8FDDH
Message 1 of 13
Using AutoCAD ObjectARX: 2023 , C++
trying to open a DWG file in MDI mode using below code :
Acad::ErrorStatus es = Acad::eOk;
if (acDocManager->isApplicationContext())
    es = acDocManager->appContextOpenDocument(strDrawingFile);
But appContextOpenDocument() fails with error Acad::eFilerError.
Opening the same DWG file in SDI mode using below API is successful :
Acad::ErrorStatus es = acedSyncFileOpen(strDrawingFile);
Please suggest how to resolve error while opening DWG file in MDI mode.
The command is registered with commandFlag as "ACRX_CMD_MODAL | ACRX_CMD_SESSION".
Also tried with executeInApplicationContext() in case when command is not registered with ACRX_CMD_SESSION.
Replies (12)
Message 2 of 13
moogalm
Autodesk Support
Autodesk Support
I don't see any error, may be you can share full code snippet.
Following code is what I tested.
void openDocHelper(void* pData)
        AcString* dwg = (AcString*)pData;
        Acad::ErrorStatus result
            = acDocManager->appContextOpenDocument(*dwg);
        if (result != Acad::eOk)
            acutPrintf(L"\nERROR: %s\n", acadErrorStatusText(result));
    else
        acutPrintf(L"\nERROR: in Document context :%s\n", acDocManager->curDocument()->fileName());
void OpenDwg()
    Acad::ErrorStatus es;
    AcString dwgpath = L"D:\\Temp\\XYZ.dwg";
    if (acDocManager->isApplicationContext()) //if Command is registered for SESSION
         es = acDocManager->appContextOpenDocument(dwgpath);
        if (es != Acad::eOk)
            acutPrintf(L"\nERROR: %s\n", acadErrorStatusText(es));
    else //if COmmand is registered for MODAL only
        acDocManager->executeInApplicationContext(openDocHelper, &dwgpath);
Message 3 of 13
I am using the same code.
PrepareForImport is getting called from a button in the ribbon in ACAD. We have a very old application, is there something at the start of loading the application can affect this?
I have attached the code and image as well.
else
void OpenDwg()
AcString dwgpath = L"F:\\Project\\FactoryCAD\\data\\sample1.dwg";
void CimfCommands::PrepareForImport()
OpenDwg();
return;
Message 4 of 13
moogalm
Autodesk Support
Autodesk Support
if PrepareForImport is a command, you need to execute this command through sendStringToExecute, that will allow execution in command context.
Message 5 of 13
cannot call directly  sendStringToExecute as we are not explicitly calling this command. its called from button
This is command registration.
 AddCommand(CimfCommands::PrepareForImport, STR_CMDUI_CIMF_UB_COMMAND, STR_CMDUI_CIMFPREPAREFORIMPORT, STR_CMDUI_CIMFPREPAREFORIMPORT, ACRX_CMD_MODAL);
Tried with and without  ACRX_CMD_MODAL/ACRX_CMD_SESSION
I think need to align code for the respective flag to get correct application context, not sure how to give it.
Message 6 of 13
moogalm
Autodesk Support
Autodesk Support
In the button logic, use Sendstringtoexcute to call the registered command, you should find many examples on the internet.
Message 7 of 13
most of the examples are calling command from some function
we didn't find example for Sendstringtoexcute  that is called from button.
we required way to do in from macro as in below image
or simply way to open the drawing on button click.
Message 8 of 13
moogalm
Autodesk Support
Autodesk Support
if `imfPrepareForImport` is command, that will be executed in application context,
This should work without any hassle
It appears to me something is missing in your environment.
Message 9 of 13
How you have added callback function to command ?
we are using
Message 10 of 13
moogalm
Autodesk Support
Autodesk Support
Just call this STR_CMDUI_CIMFPREPAREFORIMPORT this from your macro, when you click the button, the macro executes by calling the registered command, if the command is registered as MODAL, use this acDocManager->executeInApplicationContext(openDocHelper, &dwgpath);
or, if the command is registered for Session , use this es = acDocManager->appContextOpenDocument(dwgpath);
Message 11 of 13
still not got what mechanism you have used for mapping command string to function name command.
command name : STR_CMDUI_CIMFPREPAREFORIMPORT
command function : CimfCommands::PrepareForImport
can you please try with AddCommand , this is what we have in the existing application.
AddCommand(CimfCommands PrepareForImport, STR_CMDUI_CIMF_UB_COMMAND, STR_CMDUI_CIMFPREPAREFORIMPORT, STR_CMDUI_CIMFPREPAREFORIMPORT, ACRX_CMD_MODAL);
Message 12 of 13
moogalm
Autodesk Support
Autodesk Support
    else
void OpenDwg()
    else //if command is registered for MODAL only
void initApp()
    acedRegCmds->addCommand(_T("ASDK_MAKE_ENTS"),
        _T("OPENDOC"),
        _T("OPENDOC"),
        ACRX_CMD_MODAL,
        OpenDwg);
void unloadApp()
        acedRegCmds->removeGroup(_T("ASDK_MAKE_ENTS"));
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* appId)
        switch (msg) {
        case AcRx::kInitAppMsg:
		       acrxDynamicLinker->unlockApplication(appId);
				acrxDynamicLinker->registerAppMDIAware(appId);
                initApp();
                break;
        case AcRx::kUnloadAppMsg:
                unloadApp();
        return AcRx::kRetOK;
Here is code snippet I used, in the command macro just type _OPENDOC
Message 13 of 13
shaohuilv
acedRegCmds->addCommand(_T("ASDK_MAKE_ENTS"), _T("OPENDOC"), _T("OPENDOC"), ACRX_CMD_MODAL|ACRX_CMD_SESSION, OpenDwg);
