ObjectARX
jignesh.rana
228 Views, 1 Reply
open drawing
while i open drawing using appContextOpenDocument then it istaking too much time to open that drawing while i open it using by _open command then it will open immediately
and on few system drawing open using appContextOpenDocument  is quickly but on few system it is taking too much time to open that drawing
we tried to import those system settings too but issue is same
1 REPLY 1
  • what is the time difference
  • is this issue specific to one drawing only?
  • can you share issue reproducible and non-confidential dwg files to test?
  • can you share a small reproducible code sample with the open file API calls?
AutoCAD Inside the Factory
