ObjectArx 2023 Upgradation (ObjectArx 2022 to ObjectArx 2023 upgradation issue)
milindnalgirkar
milindnalgirkar
Dear member,
We tried to upgrade ObjectArx 2022 to 2023 and we got issue in deprecated API
API (ObjectArx 2022 and Deprecated ObjectArx API 2023):
We got following error for that upgradation:
Kindly Guide Us For The Same.
Thanks In Advance!!
Thanks & regards,
moogalm
Autodesk Support
Autodesk Support
We added new API getDocumentIterator to make it easier to write AutoCAD code that doesn't leak resources. The normal C++ idiom for avoiding resource leaks is RAII, and the STL provides the std::unique_ptr class that handles automatic deletion of wrapped pointers. Please use this API.
for (auto pI = ::acDocManager->getDocumentIterator(); !pI->done(); pI->step())
        AcApDocument* pApiDoc = pI->document();
 /**other code**/
daniel_cadext
I think it’s a great Idea, however the documentation is ambiguous.
“auto getDocumentIterator();
Returns a new pointer to an AcApDocumentIterator object.”
should define exactly what auto is
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
