ObjectArx 2019 debugging problem
zrobert
Message 1 of 24
zrobert
Hi;
I have a project in version 2018 and I compiled it into version 2019. Everything is ok in the release (or debug) version when it is normally loaded to Acad with the APPLOAD command. However, debugging does not work. Visual studio normally started Autocad, load application, but break points are not hit. I've created a new blank project with ObjectArx wizard 2019, compiled it and the problem is the same. Can not hit a break point. However, when compiling a project from an ObjectArx sample folder, debugging works normally!?! I try to compare this project settings, but cannot found differences (at least as far as I know).
Another thing, a project created with ObjectArx wizard, or a project from arx samples can not compile until I add this line to the project settings file.
<PropertyGroup Label="Configuration">
    <ConfigurationType>DynamicLibrary</ConfigurationType>
    <CharacterSet>Unicode</CharacterSet>
    <CLRSupport>false</CLRSupport>
    <UseOfMfc>Dynamic</UseOfMfc>
    <!-- <UseOfAtl>false</UseOfAtl> -->
    <WindowsTargetPlatformVersion>10.0.16299.0</WindowsTargetPlatformVersion>
<PlatformToolset>v141</PlatformToolset> </PropertyGroup>
Here is example project.
P.S.
I do corrections to ObjectARX wizard 2019 files as sugested Mr. Alexander Rivilis in this post.
Thanks;
Replies (23)
Message 2 of 24
moogalm
Autodesk Support
Autodesk Support
Hi
I can't reproduce the problem, I have tested wizard 2019 on VS 2017
is it possible run the command, and send me out.txt ?
msbuild ArxProject1.vcxproj /t:Build /p:Configuration=debug;Platform=x64 /pp:out.txt
Message 3 of 24
Alexander.Rivilis
I have not problem with debugging AutoCAD 2019:
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 4 of 24
zrobert
Thanks for fast replay. Here is out.txt from previous example project.
Message 5 of 24
moogalm
Autodesk Support
Autodesk Support
Thanks for the file.
You are using VS 2017 community edition, I don't have the environment at my end to test and find problem.
1) I feel the either problem is with order of property sheets, ideally explicity mentioning of this element is not required it already defined in parent props.
I.e  <WindowsTargetPlatformVersion>10.0.16299.0</WindowsTargetPlatformVersion>
 2) I noticed  - \ObjectARX 2019\inc\rxsdk_common.props
	  <TargetMachine>MachineX86</TargetMachine>
Please replace above with following code
<!--<TargetMachine Condition="'$(Platform)'=='Win32'">MachineX86</TargetMachine>
      <TargetMachine Condition="'$(Platform)'=='x64'">MachineX64</TargetMachine>-->
3) What are errors you got ?
Message 6 of 24
Alexander.Rivilis
I also using VS 2017 community edition and has not problem such as @zrobert
Expert Elite Member
Message 7 of 24
zrobert
I try this .props changes, but with no success.
About "<WindowsTargetPlatformVersion>10.0.16299.0</WindowsTargetPlatformVersion>", if I don't make this change, I got this error when compile: 1>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Platforms\x64\PlatformToolsets\v141\Toolset.targets(36,5): error MSB8036:The Windows SDK version 8.1 was not found. Install the required version of Windows SDK or change the SDK version in the project property pages or by right-clicking the solution and selecting "Retarget solution".
And, here is errors when start debuging proccess from VS:
exception 1exception 1exception 2exception 2exception 3exception 3
Message 8 of 24
Alexander.Rivilis
@zrobert
1. I see you using not pure AutoCAD 2019 but AutoCAD Map 2019 (or AutoCAD Civil 3D 2019).
2. I see LoaderLock error: https://kishordgupta.wordpress.com/2011/02/01/c-tricks-how-to-remove-loader-lock-error-in-visual-stu...
Expert Elite Member
Message 9 of 24
zrobert
Hi Aleksander;
Yes, I using Autocad Civil 3d and Map. I using this last 5 years with no problems.
Disabling Loader lock not solve problem. I found this option in arx example project (AsdkAcUiDialogSample) and this option is checked. This project I can compile and debugging without any problems.
I've lost a bit of nerves and ideas ... I do not have enough knowledge about c ++ compilling, settings etc ...
Message 10 of 24
zrobert
And, when I load arx app in Autocad and switch to VS code editor, breag point has "!" sign and report "The breakpoint will not currently be hit. No symbols have been loaded for this document".
Message 11 of 24
moogalm
Autodesk Support
Autodesk Support
Hi ,
is it ok for you to have On line screen sharing session.
let me know I will privately DM you the link.
India 2:00 PM IST (GMT +5:30 PM) Today.
Message 12 of 24
zrobert
Hi;
Yes, please send me link.
Message 13 of 24
moogalm
Autodesk Support
Autodesk Support
This is a symptom of program database is not being generated.
I have attached a project, please unzip.
Edit *.vcxproj
Find
<ObjectARXPath>D:\ObjectARX 20$(ArxVersion)</ObjectARXPath>
and change it to correct SDK Path
Find
<WindowsTargetPlatformVersion>8.1</WindowsTargetPlatformVersion>
and change it to correct Windows SDK version
Save
Build
And, test if you are able to hit breakpoint.
Message 14 of 24
zrobert
Uff....I can't compile:
1>------ Rebuild All started: Project: createTemplates, Configuration: Debug x64 ------
1>main.cpp
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(204): error C2061: syntax error: identifier 'AcColor'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(207): error C2061: syntax error: identifier 'AcColor'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(210): error C2061: syntax error: identifier 'IAcadAcCmColor'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(213): error C2061: syntax error: identifier 'IAcadAcCmColor'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(234): error C2061: syntax error: identifier 'AcShadowDisplayType'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(237): error C2061: syntax error: identifier 'AcShadowDisplayType'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(308): error C2061: syntax error: identifier 'AcExtendOption'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(317): error C2061: syntax error: identifier 'ACAD_LWEIGHT'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(320): error C2061: syntax error: identifier 'ACAD_LWEIGHT'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(324): error C2061: syntax error: identifier 'IAcadHyperlinks'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(331): error C2061: syntax error: identifier 'IAcadDictionary'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(383): error C2061: syntax error: identifier 'AcColor'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(386): error C2061: syntax error: identifier 'AcColor'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(389): error C2061: syntax error: identifier 'IAcadAcCmColor'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(392): error C2061: syntax error: identifier 'IAcadAcCmColor'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(425): error C2061: syntax error: identifier 'AcShadowDisplayType'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(428): error C2061: syntax error: identifier 'AcShadowDisplayType'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(486): error C2061: syntax error: identifier 'AcExtendOption'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(495): error C2061: syntax error: identifier 'ACAD_LWEIGHT'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(498): error C2061: syntax error: identifier 'ACAD_LWEIGHT'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(502): error C2061: syntax error: identifier 'IAcadHyperlinks'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(509): error C2061: syntax error: identifier 'IAcadDictionary'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(526): error C2061: syntax error: identifier 'AcWireframeType'
1>c:\autodesk\autodesk_objectarx_2019\inc\axboiler.h(529): error C2061: syntax error: identifier 'AcWireframeType'
1>d:\createtemplates\main.cpp(30): fatal error C1083: Cannot open type library file: 'acax22ENU.tlb': No such file or directory
1>Done building project "createTemplates.vcxproj" -- FAILED.
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
Message 15 of 24
zrobert
Ok, I do all this, and I can debugging and hit breakpoints... All working OK in your app.
Message 16 of 24
zrobert
I found a solution, thank God!
Huge problem due to very small things.
I do not know the real reason because no one else complained about it, but my computer can not debug if I do not change the following settings.
By default, ObjectArx wizard create project with this settings:
In Configuration Properties->General->Intermediate Directory is set to $(Platform)\$(Configuration)\. With this settings I can't hit break point when debugging.
When I change this settings to $(SolutionDir)$(Platform)\$(Configuration)\, everything works great!
Honestly, I do not know what these setting mean and what it is, but now everything works normally. Smiley Very Happy
Thank Mr. Madhukar for the time spent and help.
Message 17 of 24
TEK1
I have the same problem but I cannot find the tab you are referring to In Configuration Properties->General->Intermediate Directory is set to $(Platform)\$(Configuration)\.
Message 18 of 24
Alexander.Rivilis
Expert Elite Member
Message 19 of 24
TEK1
Thank you for that reply. I don't get that screen. This is what I get. It
is a C# project
[image: image.png]
Message 20 of 24
TEK1
I dont get that screen.
I get only this screen
