ObjectARX
Jig causes entities disappear
4 REPLIES 4
yysy112
404 Views, 4 Replies
Hi all,
During my jig process, if I keep zooming the screen until the "regen" process is called, all of the entities disappear.
1. It seems built-in jig will prevent the "regen" to be triggered. You can't zoom when a regen limit is hit. How to do that? any examples?
2. Is there any way to regen and show during jig process?
many thanks.
4 REPLIES 4
daniel_cadext
in reply to: yysy112
If I zoom way out in a drawing, begin drawing a line, then start zooming in, eventually I see a message on the status bar saying
“Cannot zoom in further while a command is active”
I also found this:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/AutoCAD-Zoom-only-...
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
yysy112
in reply to: daniel_cadext
hi daniel,
Thanks for your reply. I tried to do my jig process in a command, it just works as you said.
But if my jig process is called by a modeless dialog, the "zooming scale limit" does't work then.
In my case, I have a modeless dialog. I hit a button, a circle is created and the jig process starts.
tbrammer
A modeless dialog runs in "session context" and not in document context. This affects the behaviour of AutoCADs graphic system.  Also modeless dialog boxes must handle the WM_ACAD_KEEPFOCUS message as explained here to keep the focus. I suppose that you must avoid to keep the focus while the jig is running.
The cleanest solution is to register a modal command that executes your jig and start it with AcApDocManager::sendStringToExecute() as explained here. Hide and/or "deactivate" your dialog while the command runs and re-activate it when it ends.
Also use
AcAxDocLock lock;
// your jig here...
to lock the current document before you start the jig. Maybe this already helps.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
yysy112
in reply to: tbrammer
AcApDocManager::sendStringToExecute() seems to be the only way to solve my problem.
AutoCAD Inside the Factory
