How i can save my bin files in dwg?
Hello! How can I store a file, for example, in the bin format in a dwg drawing? Or associate the file with the object (and perhaps store this file in the object)? Thanks a lot!
tbrammer
Here are some suggestions to try:
  1. Via OLE using an AcDbOle2FrameAcDbOle2Frame is derived from AcDbEntity.
    Looks like you have to create a COleClientItem (MFC class) and call
    AcDbOle2Frame::setOleClientItem(oleItem).
  2. Using an AcDbXRecord. You must break your binary data into resbufs that contain up to 127-byte chunks.
    Probably the easiest solution.
  3. Using a custom object. Derive your own class from AcDbObject and implement dwgInFields()
    and dwgOutFields().
I never tried any of these ways myself to store binary data. But I think #2 would be my first choice to try.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
dgorsman
Keep in mind, when an outside agency finds "mystery data" (encrypted, binary, or otherwise not easily readable) in a drawing file they may strip it out if not reject the file altogether.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
