ObjectARX
how can i convert a region to a polyline?
5 REPLIES 5
514 Views, 5 Replies
whitch command convert a region to a polyline?
nicel3
ondraw@hotmail.com
5 REPLIES 5
You will have to open the AcDbRegion, explode it. Then use the
AcDbVoidPtrArray returned. Note that the original Region will not be
exploded as AutoCAD-explode, but you will get all the entities that autocad
would have created in the array. You will have to erase the region your self
if thats what you want to do.
Now to the fun part!
The array may include Lines, Arcs and/or Splines. So you have to create your
polyline from this array all by your self.
"Glad niceguyl3" wrote in message
news:D4A126D590099675B5FB4573B3088793@in.WebX.maYIadrTaRb...
> nicel3
> ondraw@hotmail.com
thank you very much, 🙂
nicel3
ondraw@hotmail.com
"zatopek" wrote in message
news:E23018745BF9A5F40B7BB027CADC4334@in.WebX.maYIadrTaRb...
autocad
self
your
> > nicel3
> > ondraw@hotmail.com
jignesh.rana
can any one share the code of this logic ?
wispoxy
To convert a region to a polyline in AutoCAD using ObjectARX, you would typically follow these steps:
  1. Open the AcDbRegion object.
  2. Explode the region to get the constituent curves.
  3. Use the AcDbVoidPtrArray returned by the explode operation.
  4. Create a new polyline and add the exploded curves to it.
  5. Erase the original region if necessary.
Here’s a simplified code snippet that outlines the process:
// Assume pRegion is a pointer to your AcDbRegion object
AcDbVoidPtrArray curveSegments;
pRegion->explode(curveSegments); // Explode the region into constituent curves
// Create a new polyline
AcDbPolyline* pPolyline = new AcDbPolyline();
// Iterate through the curve segments and add them to the polyline
for (int i = 0; i < curveSegments.length(); ++i) {
    AcDbEntity* pEntity = static_cast<AcDbEntity*>(curveSegments[i]);
    // Check if the entity is a line, arc, or spline and add it to the polyline
    // You may need to convert arcs and splines to polyline segments
// Add the polyline to the drawing and erase the original region if needed
Remember to handle memory management appropriately when working with pointers and arrays in ObjectARX.
tbrammer
See this topic.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
”Boost
