Running HlrArxSample in ObjectARX 2022 folder cannot get output for most Test.
Trying to remove hidden lines in reference block which is collection of 3d solids.
On Test2 in paper space output messages:
Command: TEST2
Select objects: 1 found
Select objects:
About to call hidden Line calculation
Calling with 1 Entities
kProject On
kShowAll Off
kEntity On
kBlock On
kSubentity Off
kHideTangents Off
kCleanup Off
kIsolines Off
kUnite Off
kReuse Off
kProgress Off
kHandlePoints Off
kHonorInternals On
kMeshSilhouettes Off
Please enter point 1:
Checking 1128 intersections...
Please enter point 2:
Too many objects selected for INTERSECT
Front Clipping is 0
Front Clipping is 1
Back Clipping is 0
Back Clipping is 1
Modeling Operation Error:
Error Code Number is 5024
Error Code Number is 115073
Last 2 error codes 5024, 115073 repeating couple times.
Test5 is not returning any curves either:
Command: TEST5
Select objects:
kProject On
kShowAll Off
kEntity On
kBlock On
kSubentity Off
kHideTangents Off
kCleanup Off
kIsolines Off
kUnite Off
kReuse Off
kProgress Off
kHandlePoints Off
kHonorInternals On
Checking 1081 intersections...
Front Clipping is 0
Front Clipping is 1
Back Clipping is 0
Back Clipping is 1
Any idea how to run correctly HlrArxSample? Should it be done in model or paper space? what are 2 points sample is asking for (Point1, Point2)?
Thank you
