(help)Find the maximum value of the sum of all arrs and the maximum value is less than target=30
463017170
463017170
Help me! Where is the problem?
class Solutionsubsets_targe {
public:
	vector<double> res;
	void dfs(vector<double>& nums,int start,double& track,double target)
		if ( track < target)
			res.push_back(track);
		for(int i=start;i<nums.size();i++)
			if (FindDouble(res, track + nums.at(i) , 1.0E-7) < 0 )
				track += nums.at(i);
			dfs(nums,i+1,track,target);
			track -= nums[i];
		return ;
	vector<double> subsets(vector<double>& nums,double target) {
		double track = 0;
		dfs(nums,0,track,target);
		return res;
static int  FindDouble(vector<double> VD, double D, double tol /*= 1.0E-7*/)
	for (int i = 0; i < VD.size(); i++)
		if ( fabs(VD.at(i)-D) <tol )
			return 1;
	return -1;
static void  MyGroupMyCommand ()
   vector<double> arr;
   arr.push_back(1.1);arr.push_back(2.1);arr.push_back(3.1);arr.push_back(4.1);;arr.push_back(5.1);
   arr.push_back(6.1);arr.push_back(7.1);arr.push_back(8.1);arr.push_back(9.1);;arr.push_back(10.1);
  Solutionsubsets_targe bb;
  vector<double> b= bb.subsets(arr,30);
daniel_cadext
You might have a look at Google’s  OR-Tools @ https://developers.google.com/optimization
I wrapped their traveling salesman solver for autolisp, to find the shortest polyline. Anyway, they have packing solvers, Knapsack, bin-packing etc.  You can use my project as a guide to working with their libraries with ARX.
BTW, some of their solvers are multi-threaded, yeah, for that CPU burn.
TSP Discussion is here: https://www.theswamp.org/index.php?topic=58049.0
My solution is here: https://drive.google.com/file/d/1wwZQ-wIL-6lh6A-QILNyzYU5-TttKeA6/view?usp=share_link
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Thank you for your help! I cannot open this webpage, can I post the code to the forum?
daniel_cadext
Which one? You’d need to access OR-Tools docs to see their samples, instructions etc.
tbrammer
First: This is not an ObjectARX question at all. Maybe you get better answers if you post it to a general C++ or algorithm forum.
I'll try to help you anyway, because I like this kind of problems 😁.
Your original question was: "Where is the problem?".
Honestly I can't answer this question because I didn't understand which algorithm you tried to implement.
I wrote a console application that finds the best solution and also prints out the combination it tried to find it.
The main part of the code looks like this:
void findBest()
	for (;;) // go forth and back until we can't go back anymore.
		forth();
		if (!back())
			break;
These classes are involved:
class ValCount {
	double   _val;		// value i.e. 10.1, 8.1,,,
	unsigned _count;	// how many times this value can be used. (always 1 with the sample data)
	double   _sumAll;   // sum of (_cout * _val) of this and all follwing ValCount entries in the array
class Result {
	vector<unsigned>	_counts;
	double				_sum = 0.0;
class ValSum {
	const vector<ValCount>& _valArr; // input data, preprocessed: Sorted for descending _val
	const double		    _target; // 30.0
	size_t					_index; // current index
	vector<unsigned>		_counts; // how many times is _valArr[i]._val in the addition
	double					_sum; // current sum
	Result					_best; // current best solution
	void findBest();
	void forth();
	void back();
The output looks like this:
Short explanation how forth() and back() work for the first lines:
One might expect that we need to check 2^N = 1024 combinations if we have N summands.
But actually we only need to check a small fraction of them.
The complete code is bellow. I hope the comments are sufficieent to explain how it works. Otherwise feel free to ask..
#include <vector>
#include <map>
#include <algorithm>
using namespace std;
void fillVector(vector<double>& arr)
	arr.push_back(1.1); arr.push_back(2.1); arr.push_back(3.1); arr.push_back(4.1);; arr.push_back(5.1);
	arr.push_back(6.1); arr.push_back(7.1); arr.push_back(8.1); arr.push_back(9.1);; arr.push_back(10.1);
class ValCount
public:
	ValCount(const double& v, const unsigned& cnt, const double& sumAll)
		: _val(v), _count(cnt), _sumAll(sumAll)
	double   _val;
	unsigned _count;
	double   _sumAll;
static void print(const vector<unsigned>& counts, const double& sum, const double& target, const char* msg = "")
	for (size_t i = 0; i < counts.size(); ++i)
		printf("%d, ", counts[i]);
	printf("  Sum = %lf, Diff = %lf%s\n", sum, target - sum, msg ? msg : "");
class Result
public:
	double				_sum = 0.0;
public:
	void print(const double& target, const char* msg = "")
		::print(_counts, _sum, target, msg);
class ValSum
private:
	size_t				_index;
	double				_sum;
	Result				_best;
public:
	ValSum(const vector<ValCount>& valArr, double trg)
		: _valArr(valArr), _sum(0.0), _counts(valArr.size(), 0), _target(trg), _index(0)
	void findBest()
			forth();
			if (!back())
				break;
	// Here we start at index, increment index and add as many elements as possible to the addition
	// All counts[i] with i>index are 0.
	// We end up with index being the index of the last added element.
	// If the result is better than the best result yet, we choose the new result.
	void forth()
		const size_t arrSize = _counts.size();
		size_t indexNew = _index;
		for (; _index < arrSize; ++_index)
			const ValCount& vc = _valArr[_index];
			unsigned n = (unsigned)((_target - _sum) / vc._val);
			n = min(n, vc._count);
			_counts[_index] = n;
			if (n > 0)
				_sum += vc._val * n;
				indexNew = _index;
		_index = indexNew; //highest modified index.
		if (_sum > _best._sum)
			// found better solution
			_best._counts = _counts;
			_best._sum = _sum;
			_best.print(_target, " new best");
		else
			::print(_counts, _sum, _target, "");
	// Here we start at _index and remove the last added element _counts[_index] first.
	// If the sum of all elements _valArr[i]._val with i>_index is big enough to sum up to target, we go forth with ++_index
	bool back()
		if (_index == 0)
			return false; // can't go back any further
		for (;; --_index)
			unsigned& cnt = _counts[_index];
			if (cnt > 0)
				if (_index < _counts.size() - 1)
					--cnt;
					_sum -= _valArr[_index]._val;
					if (_sum + _valArr[++_index]._sumAll >= _best._sum) // can we reach target with a lower difference?
						return true; // Yes. Let's go forth()
					// No. Even if we sum up all remaining elements. Go back further.
				else
					// this is the last entry in counts[]. We can't go forth from here
					_sum -= _valArr[_index]._val * cnt;
					cnt = 0;
			if (_index == 0)
				return false; // can't go back any further (note: index is unsigned)
static void MyMaxSum()
	vector<double> arr;
	fillVector(arr);
	map<double, unsigned> val2count;
	for (const double& val : arr)
		val2count[val]++;
	vector<ValCount> valArr;
	arr.reserve(val2count.size());
	double sumAll = 0.0;
	for (const auto& entry : val2count)
		sumAll += entry.first * entry.second;
		valArr.push_back(ValCount(entry.first, entry.second, sumAll));
	reverse(valArr.begin(), valArr.end());
	ValSum valsum(valArr, 30.0);
	valsum.findBest();
int main()
	MyMaxSum();
	getchar();
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Thank you very much. Let me learn.
