Help, AcDbSortentsTable Class is not working properly in ObjectARX 2019
7598165
7598165
hello all:
For INSERT(AcDbBlockTableRecord), non-Model_Space or Paper_Space
AcDbSortentsTable Class is not working properly in ObjectARX 2019.
The following code is the entity or selection set , according to the blocktable space belonging to draworder(moveBottom) operation, the code is normal in AUTOCAD 2004-2018, but no effect in 2019.
es = pSt->moveToBottom(ids );
The return value of es is eOk,
Ask for help.
thanks.
int moveToBottom()
	resbuf *rb = ads_getargs();
	if (!rb)
		return RSRSLT;
	AcDbObjectIdArray ids, ids1;
	AcDbObjectId id;
	Acad::ErrorStatus es;
	int i = 0;
	AcDbObjectId ownerId;
	while (rb) {
		if (rb->restype == RTENAME) {
			if (acdbGetObjectId(id, rb->resval.rlname) == eOk)
				if (!i)
					AcDbEntity *pEnt;
					es = acdbOpenObject(pEnt, id, kForRead);
					if (es == eOk)
						ownerId = pEnt->ownerId();
						pEnt->close();
					else
						return RSRSLT;
				i = 1;
				ids.append(id);
		else if (rb->restype == RTPICKS) {
			es = XdDbUtils::getIdArrayFromPickSet(rb->resval.rlname, ids1);
			if (es != Acad::eOk) {
				rb = rb->rbnext;
				continue;
			if (!i)
				AcDbEntity *pEnt;
				es = acdbOpenObject(pEnt, ids1[0], kForRead);
				if (es == eOk)
					pEnt->close();
				else
					return RSRSLT;
			i = 1;
			ids.append(ids1);
		rb = rb->rbnext;
	if (ids.isEmpty())
		return RSRSLT;
	AcDbSortentsTable *pSt=NULL;
	AcDbBlockTableRecord *pRec;
	if (Acad::eOk != acdbOpenObject(pRec, ownerId, AcDb::kForRead))
		return RSRSLT;
	AcDbObjectId ext_id = pRec->extensionDictionary();
	if (AcDbObjectId::kNull == ext_id)
		if (Acad::eOk != pRec->upgradeOpen())
			pRec->close();
			return RSRSLT;
		pRec->createExtensionDictionary();
			pRec->close();
			return RSRSLT;
	pRec->close();
	AcDbDictionary *pExt;
	Acad::ErrorStatus es = acdbOpenObject(pExt, ext_id, AcDb::kForRead);
	if (Acad::eOk != es)
		return RSRSLT;
	AcDbObject *pObj;
	if (Acad::eOk != pExt->getAt(_T("ACAD_SORTENTS"), pObj, AcDb::kForWrite))
		if (Acad::eOk != pExt->upgradeOpen())
			pExt->close();
			return RSRSLT;
		pSt = new AcDbSortentsTable;
		if (NULL == pSt)
			pExt->close();
			return NULL;
		AcDbObjectId new_id;
		if (Acad::eOk != pExt->setAt(_T("ACAD_SORTENTS"), pSt, new_id))
			delete pSt;
			pExt->close();
			return NULL;
	else {
		pSt = (AcDbSortentsTable *)pObj;
	pExt->close();
        pSt->setBlockId(ownerId);
	es = pSt->moveToBottom(ids);
	pSt->close();
	acedUpdateDisplay();
	ads_rett();
	return RSRSLT;
Is the 2019 ARX bug?
who can help me?
thanks!!
deepak.a.s.nadig
Thank you for reporting.
We have updated the Engineering team with this issue.
bim8QKRA
Any update with this? It is not working either for me in Autocad2019, but it is in 2018
(defun c:test ( / acblk acdoc acsel name obj processed )
(setq acdoc (vla-get-activedocument (vlax-get-acad-object))
acblk (vla-get-blocks acdoc)
(if (ssget "_X" '((0 . "INSERT")))
(progn
(vlax-for block (setq acsel (vla-get-activeselectionset acdoc))
(if (not (member (setq name (vla-get-name block)) processed))
(lambda ( / lst )
(vlax-for obj (vla-item acblk name)
(if (eq "AcDbHatch" (vla-get-objectname obj))
(progn
(setq lst (cons obj lst))
(vla-put-color obj "5")
(if lst
(vla-movetobottom (LM:SortentsTable (vla-item acblk name))
(vlax-make-variant
(vlax-safearray-fill
(vlax-make-safearray vlax-vbobject (cons 0 (1- (length lst)))) lst
(setq processed (cons name processed))
(vla-regen acdoc acallviewports)
(princ)
(defun LM:SortentsTable ( space / dict result )
(cond
(not
(vl-catch-all-error-p
(setq result
(vl-catch-all-apply 'vla-item
(list (setq dict (vla-GetExtensionDictionary space)) "ACAD_SORTENTS")
result
( (vla-AddObject dict "ACAD_SORTENTS" "AcDbSortentsTable") )
(vl-load-com) (princ)
