Grid no longer visible after a call to AcApLongTransactionManager::checkOut
fehrsZBFB9
fehrsZBFB9
Hi Community,
I'm using a long Transaction. When I call checkOut, the grid is no longer visible. It is still activated but not drawn. This does not happen in wireframe2d. How can I refresh the display to show the grid again? Neither REGEN nor REGEN3 does the job. When I call acedColorSettingsChanged it is visible again. But this is a hack and acedColorSettingsChanged is undocumented.
Alexander.Rivilis
What about disable hardware acceleration?
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
fehrsZBFB9
Same behaviour with disabled hardware acceleration. I'm using a Jig class directly after I activated the longtransaction. At other points in my code it works as expected.
Alexander.Rivilis
As far as acedColorSettingsChanged can help you and this function is in ObjectARX SDK since version 2007 - so you can use it without restriction. Also this function was proposed by @moogalm  some years ago as a solution in >>>this topic<<<
Expert Elite Member
