ObjectARX
Given the startpoint, endpoint, and centerpoint,, draw an arc (incorrect)
17 REPLIES 17
Message 1 of 18
1127204185
1026 Views, 17 Replies
Three points of space
1、startpoint    AcGePoint3d& pt1
2、endpoint  AcGePoint3d& pt2
3、centerpoint  AcGePoint3d& ptcen
	static AcDbArc* CreatArc(const AcGePoint3d& pt1, const AcGePoint3d& pt2, const AcGePoint3d& ptcen, bool mode)
		AcGePoint3d ptmid = AcGePoint3d((pt1.x + pt2.x) * 0.5, (pt1.y + pt2.y) * 0.5, (pt1.z + pt2.z) * 0.5);
		AcGeVector3d vecmid = ptmid - ptcen;
		vecmid.normalize();
		ptmid = mode ? ptcen + vecmid * (ptcen.distanceTo(pt1)) : ptcen - vecmid * (ptcen.distanceTo(pt1));
		AcGeCircArc3d geArc(pt1, ptmid, pt2);
		AcDbArc* pArc = new AcDbArc(geArc.center(), geArc.normal(), geArc.radius(), geArc.startAng(), geArc.endAng());
		return  pArc;
17 REPLIES 17
Message 2 of 18
ynapeu
in reply to: 1127204185
please try this
void CreateArc3D(const AcGePoint3d& center, const AcGePoint3d& startPoint, const AcGePoint3d& endPoint)
AcGeVector3d vec1 = startPoint - center;
AcGeVector3d vec2 = endPoint - center;
AcGeVector3d normal = vec1.crossProduct(vec2);
normal.normalize(); // Normieren des Normalenvektors
AcGeVector3d xAxis = vec1.normal();
AcGeVector3d yAxis = normal.crossProduct(xAxis);
AcGePlane plane(center, normal);
AcGePoint2d start2D = plane.paramOf(startPoint);
AcGePoint2d end2D = plane.paramOf(endPoint);
double radius = center.distanceTo(startPoint);
double startAngle = AcGeVector2d(start2D).angle();
double endAngle = AcGeVector2d(end2D).angle();
AcDbArc* pArc = new AcDbArc(center, normal, radius, startAngle, endAngle);
Message 3 of 18
1127204185
Thank you. Is there an algorithm that can divide this arc equally?
Message 4 of 18
1127204185
in reply to: ynapeu
Thank you.
Message 5 of 18
1127204185
in reply to: ynapeu
const AcGePoint3d& center, const AcGePoint3d& startPoint, const AcGePoint3d& endPoint What if the three points are collinear?
AcGeVector3d normal = ?
AcGeVector2d(start2D)==start2D.asVector()?
I just want to solve for three non collinear points, generate an arc, and obtain the node coordinates of the arc segments?
Message 6 of 18
ynapeu
If the three points are collinear, they all lie on a straight line. This means that no unique circle can be formed through these three points. Typically, for constructing a circle, it is expected that the points do not lie on a straight line, as a circle requires at least two different directions to define both the center and the radius unambiguously. However, if they are collinear, no circle can exist mathematically.
Message 7 of 18
daniel_cadext
You can also have a look at using AcGeCircArc3d and acdbAssignGelibCurveToAcDbCurve. AcGeCircArc3d has a constructor that accepts three points
import traceback
from pyrx_imp import Ap, Db, Ed, Ge, Gi, Gs, Rx
def PyRxCmd_doit():
    try:
        db = Db.curDb()
        ps, pnt1 = Ed.Editor.getPoint("\nFirst")
        ps, pnt3 = Ed.Editor.getPoint("\nSecond")
        ps, rad = Ed.Editor.getDouble("\nRadius")
        pnt2 = pnt1 + ((pnt3 - pnt1) * 0.5)
        pnt2 = pnt2 + (Ge.Vector3d.kXAxis * rad)
        garc = Ge.CircArc3d(pnt1,pnt2,pnt3)
        crv = Db.Arc()
        Db.Core.assignGelibCurveToAcDbCurve(garc,crv)
        db.addToModelspace(crv)
    except Exception as err:
        traceback.print_exception(err)
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Message 8 of 18
1127204185
in reply to: daniel_cadext
	AcGePoint3d p1, p2, p3;
	    if (RTNORM != acedGetPoint(NULL, L"\n第一点:: ", asDblArray(p1))
		||  RTNORM != acedGetPoint(NULL, L"\n第二点:: ", asDblArray(p2))
		||  RTNORM != acedGetPoint(NULL, L"\n第三点:: ", asDblArray(p3)))
		acutPrintf(L"\nFunction canceled\n" );
		return;
	AcGeCircArc3d geArc(p1, p2, p3);
	AcDbArc *pArc = NULL;
	AcDbCurve::createFromAcGeCurve(geArc, (AcDbCurve*&) pArc);
AcDbCurve::createFromAcGeCurve(geArc, (AcDbCurve*&) pArc);  Does this function not exist in lower versions?
How to ask correctly? startAngle   endAngle ?
Message 9 of 18
daniel_cadext
the global versions should be in since before 2013
acdbConvertAcDbCurveToGelibCurve
acdbConvertGelibCurveToAcDbCurve
Message 10 of 18
1127204185
vs2010?
Message 11 of 18
daniel_cadext
I don’t know, but you can probably do that your self from the properties of the constructed AcGeCircArc3d
Message 12 of 18
1127204185
Then we need to recalculate startAngle and endAngle?
Message 13 of 18
daniel_cadext
no, those will be calculated for you in AcGeCircArc3d class
Message 14 of 18
yeah, seems is doing some extra math
Message 15 of 18
import traceback
def PyRxCmd_doit():
    try:
        db = Db.curDb()
        crv =  Db.Core.convertGelibCurveToAcDbCurve(garc)
        garc2 =  Ge.CircArc3d.cast(crv.getAcGeCurve())
        print(garc.center(),garc.radius(),garc.startAng(),garc.endAng())
        print(garc2.center(),garc2.radius(),garc2.startAng(),garc2.endAng())
(-119.99999999999990,50.00000000000000,0.00000000000000) 129.99999999999991 0.0 0.7895822393995233
(-119.99999999999990,50.00000000000000,0.00000000000000) 129.99999999999991 2.746801533890032 3.536383773289555
Message 16 of 18
kinda seems like a bug?
import traceback
def PyRxCmd_doit():
    try:
        db = Db.curDb()
        garc2 =  Ge.CircArc3d.cast(Db.Core.convertAcDbCurveToGelibCurve(crv))
(-120.00000000000004,49.99999999999999,0.00000000000000) 130.00000000000003 0.0 0.789582239399523
(-120.00000000000004,49.99999999999999,0.00000000000000) 130.00000000000003 5.8883941874798245 6.677976426879347
Message 17 of 18
ynapeu
Hello, you can use getSamplePoints.
Message 18 of 18
1127204185
in reply to: ynapeu
    AcDbArc(const AcGePoint3d& center, double radius,
            double startAngle, double endAngle);
    AcDbArc(const AcGePoint3d& center, const AcGeVector3d& normal,
            double radius, double startAngle, double endAngle);
Are there only these two ways to achieve it?
AutoCAD Inside the Factory
