ObjectARX
Get the vertex of a polyline (curve) according to the point on curve
5 REPLIES 5
majklha
369 Views, 5 Replies
I have a curve (eg. acdbPolyline or acdbMPolygon) and a point. I know the point is on the curve. (I used GetClosestPointTo....)
How I get a vertex of the Poly, whitch the point lies on?
5 REPLIES 5
in reply to: majklha
what do you want? all vertex on the polyline?
int num = poly->numberVertex();
for(int i = num; i < num; i++)
acgePoint2d pt;
poly->getpointAt(i, pt);
is this what you need?
majklha
in reply to: 835700012
Thanks for reply and sorry for bed question.
I try to write it other way: I have a point and I know, it lies on the polyline (curve).
I need to find out, which vertex it belongs to.
acgepoint2d yourPt;
acgePoint2d pt;
if(pt.DistanceTo(yourPT) < 1e-3)
return i;
get the distance you can find out the index you need
majklha
It does not work.
Because I have a point somewhere on vertex but getPointAt(int, pt) return begin point of vertex.
My code:
//pEntPol IS SELECTED BY SSGET
AcDbPolyline *pPoly = AcDbPolyline::cast(pEntPol);
if(!pPoly)
	pEntPol->close();
	return;
int res = RTNORM;
while(res == RTNORM)
	ads_point arPt;
	res = acedGetPoint(NULL, L"\nZadej bod:", arPt);
	if(res == RTNORM)
		AcGePoint3d ptBod = asPnt3d(arPt);
		AcGePoint3d ptNear;
		pPoly->getClosestPointTo(ptBod, ptNear);
		MajDraw::UkazBod(asPnt2d(ptNear)); //it shows point on autocad - blue
		///ptNear - point somewhere on polyline
		for(int i = 0; i < pPoly->numVerts(); i++)
			AcGePoint2d pt;
			pPoly->getPointAt(i, pt); //find base point of Vertex
			MajDraw::UkazBod(pt); //it shows point on autocad - yellow
			if(pt.distanceTo(asPnt2d(ptNear)) < 1e-3)
				acutPrintf(L"\nVertex No: %i", i);
pEntPol->close();
majklha
I have solved it.
				double param;
				if(pPoly->onSegAt(i, asPnt2d(ptNear), param) == Adesk::kTrue)
					acutPrintf(L"\nVertex No: %i, param %.3f", i, param);
 The found method is onSegAt(..).
Autodesk Customer Advisory Groups
