error: ARXLOAD failed
REllard
REllard
I have the following lisp
(defun c:LayTransAuto()
(cond ((not (member "laytrans.arx" (arx))) (arxload "laytrans")))
(acet-laytrans "newlayers.dws" 0)
(princ))
and the following script that calls the above lisp
(load "laytrans.lsp" nil)
(c:LayTransAuto)
_.qsave
_.close
When I load this lsp into appstart, I can call the function and it runs as expected. How ever when I run the script that calls the lisp via the Batch Save Utility I get the following error.
Command: (load "laytranslsp.lsp" nil)
C:LAYTRANSAUTO
Command: (c:LayTransAuto)
; error: ARXLOAD failed
Command: _.qsave
Command: _.close
SeeMSixty7
I'm not familiar with the Batch Save utility, but it may be an issue with the arx file not being on the path of the utilities environment. Try specifying the entire path of the arx file.
i.e.
(arxload "C:\\Program Files\\Autodesk\\AutoCAD 2020\\laytrans.arx")
You can use (findfile "laytrans.arx") to get the above path.
See if that helps.
Good luck,
REllard
That also gave me the same error. Thank you for your reply though. Error is below from the detailLog
Command: (arxload "C:\\Program Files\\Autodesk\\AutoCAD 2019\\Laytrans.arx")
Alexander.Rivilis
(princ))
(c:LayTransAuto)
_.qsave
_.close
C:LAYTRANSAUTO
Command: _.qsave
Command: _.close
Looks like problem with path to "laytrans.arx". This file have to be in Support File Search Path:
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
REllard
Thank you Alexander, I have done what you suggested also and I still get the same error.
Alexander.Rivilis
Batch Save Utility use AutoCAD or AcCoreConsole? If it use AcCoreConsole you can use only crx-files but not arx-files.
You can try:
1) to do copy of Laytrans.arx with name Laytrans.crx
2) use (arxload "laytrans.crx") instead of (arxload "laytrans")
But as far as Laytrans.arx dependent on acad.exe those manipulation can not help you...
Expert Elite Member
REllard
Thank you so much I have been banging my head on this one for a week. What fixed it for me was making a copy of the Laytrans.arx file as Laytrans.crx file.
