Announcements
Draging line
KIMHENGHOR98
Draging line
KIMHENGHOR98
I want to make a line which the start point is dragging a long polyline and the end point dragging for cursor.
please someone could help me <<<<<>>>>>
tbrammer
I don't understand what exactly you are asking for. You want to make a line. So you need startpoint and endpoint.
What do you mean by: "start point is dragging a long polyline"? Do you have a given polyline, want to drag it's endpoint and then use the new endpoint as startpoint for the new line?
If you have a given startpoint ptStart you could simply use acedGetPoint(ptStart, L"Endpoint:" ptEnd) to select the endpoint ptEnd. AutoCAD will draw a rubber-band line from ptStart to the cursor point then.
A more sophisticated and flexible approach is to use an jig (AcEdJig). See sample  <ArxSdk>\samples\database\elipsjig_dg.
At which point do you need help? Selecting the points? Implementing a jig? Creating the line entity?
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
KIMHENGHOR98
I have a polyline the thing is : I want to create a line Enity derived from acdbPolyline but when I am drawing that entity it’s starting point is moving through that polyline while dragging its end point with cursor
tbrammer
Check out the attached project. It is based on the sample <ARX>\samples\database\elipsjig_dg.
Compile, start AutoCAD and load the plineLine.arx. Make sure you have a polyline and a line in your drawing and enter "PLJ". Select the line then the polyline.
KIMHENGHOR98
Thanks you very much I understood how to use getClosestPointTo()
