ObjectARX
Disabling DROPGEOM
62 REPLIES 62
Message 1 of 63
Kyudos
18274 Views, 62 Replies
Disabling DROPGEOM
I've found that dealing with OLEDRAGDROP / DROPGEOM as well as grip editing makes the handling for my custom objects unnecessarily complicated.
Hence I'm posting my solution to disabling this function for my objects, I don't know if its the best way, but it works.
In your AcApDocManagerReactor::documentLockModeChanged handler you can use something like this:
if (_tcsicmp(pGlobalCmdName, _T("OLEDRAGDROP")) == 0 ||
_tcsicmp(pGlobalCmdName, _T("DROPGEOM")) == 0 ||
_tcsicmp(pGlobalCmdName, _T("DRAGENTER")) == 0)
    // Prevent objects from being dragged
    for (int i = 0; i < aLastSelectionArray.length(); i++)
        AcDbObjectId objId = aLastSelectionArray[i];
	MyObject* pObj = IsMyObject(objId);
        if (pObj != NULL)
            this->veto();
            break;
Tags (3)
62 REPLIES 62
Message 41 of 63
chungenlin45254
in reply to: Kyudos
Hi Kyudos! Is there any posibility to have a 2012 compatible version? :folded_hands:
Message 42 of 63
Kyudos
in reply to: chungenlin45254
I can't build it without the ObjectARX 2012 SDK - and I can't find a working download link. It doesn't appear to be on AutoDesk's servers anymore.
If you can find a link I can make it.
Message 43 of 63
Alexander.Rivilis
in reply to: Kyudos
https://download.autodesk.com/esd/objectarx/2012/ObjectARX_2012_Win_64_and_32Bit.exe
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 44 of 63
Kyudos
in reply to: Alexander.Rivilis
Thanks Alexander - I tried several of your other links (in other posts) and none of them seemed to be active!
Message 45 of 63
Alexander.Rivilis
in reply to: Kyudos
@Kyudos
Some years ago link begin with http: and now begin with https:
Expert Elite Member
Message 46 of 63
Kyudos
in reply to: Kyudos
@chungenlin45254 Untested, but should work.
Message 47 of 63
chungenlin45254
in reply to: Kyudos
sorry for replying so late!
I've tried to install it but it says the following,
"disabledragdrop.arx is incompatible with this version of AutoCAD.
AcRxDynamicLinker failed to load "
I've found some other versions of ObjectARX SDK provided by Alexander in the link below.
Some of them are also compatible with autocad 2012. I'm not sure if this will help.
Thank you so much.
Message 48 of 63
Kyudos
I don't have a 2012 version of AutoCAD, so I can't really test this I'm afraid. Did you try both the debug and release versions?
Message 49 of 63
chungenlin45254
in reply to: Kyudos
I'm afraid so.
I've tried both the debug and release versions and they all failed to load...
Message 50 of 63
CDM2424
in reply to: Kyudos
Thanks for doing this! However, it doesn't appear to work. I had used it on 2020, and it worked flawlessly. Now with the 2023 version of CAD and the 2023 version of your arx, it doesn't seem to work at all. No errors in the command line either.
Message 51 of 63
Kyudos
in reply to: CDM2424
Hmmm...it works fine here (in Version T.181.0.0 AutoCAD 2023.1.4).
There's not much that can go wrong with it really, so I'm not sure what to suggest.
What do you see on the command line when you APPLOAD it? It should look like this:
Command: APPLOAD
Available commands:
DISABLEDD : disable drag and drop
ENABLEDD  : enable drag and drop
ENABLEDO : enable drag override
DISABLEDO  : disable drag override
DisableDragDrop.arx successfully loaded.
Message 52 of 63
CDM2424
in reply to: Kyudos
Appreciate the fast response.
I see the same thing.
Command: APPLOAD
Available commands:
DisableDragDrop2023.arx successfully loaded.
My CAD version.
Message 53 of 63
Kyudos
in reply to: Kyudos
Does it make a difference if you load it into the vanilla AutoCAD that underlies your Civil 3D? (I don't have C3D on my machine ATM so can't test it)
Message 54 of 63
CDM2424
in reply to: Kyudos
It doesn't work in vanilla either.
Message 55 of 63
Kyudos
Neither of the functions?
Message 56 of 63
CDM2424
in reply to: Kyudos
Ok.... So.... I'm dumb. I forgot that I had previously added the command to "acaddoc.lsp"... I did this a while ago and this made me thing the commands were already enabled on startup straight from the arx.
I added it back as a startup command, and all is well. Thank you so much for your quick replies and for helping me through my own stupidity haha.
Message 57 of 63
Kyudos
Haha! No problem. I find I often use the "ask on the forum" technique to solve problems. That is, you bash your head against something for hours/days, then ask on a forum about it, and subsequently and immediately solve it and have to answer your own forum question :winking_face:
Message 58 of 63
CDM2424
in reply to: Kyudos
Haha, so true. I knew it had to be a simple solution. Sometimes I just get in my own way. Thanks again for all your help!!
Message 59 of 63
jan.bartlomiejczyk
in reply to: Kyudos
Hi, i know that this forum is for AutoCAD users, but in my new work i've got GstarCAD on my computer and very anoying problems with DROPGEOM . Gstar is not working with ARX files but GRX instead. I saw this video https://www.youtube.com/watch?v=HFAHoAOd1YY about changing ARX to GRX and it looks easy to do but not for an Architect who doesnt know anything about programing :D. Could you please help me and post the GRX file by chance?
Message 60 of 63
jan.bartlomiejczyk
in reply to: Kyudos
Hi, i know that this forum is for AutoCAD users, and i used Autocad for years, but now in my new work i've got GstarCAD and anoying problems with DROPGEOM. Gstar is not working with ARX but the GRX instead. I saw this video https://www.youtube.com/watch?v=HFAHoAOd1YY about how to change ARX to GRX and it looks easy but not for an Architect who doesnt know anything about programing :D. Could you please help me and post the GRX file by chance?
AutoCAD Inside the Factory
