Disabling DROPGEOM
Kyudos
Disabling DROPGEOM
Kyudos
EDIT: For convenience I'm just adding the latest builds to this first post 🙂
I've found that dealing with OLEDRAGDROP / DROPGEOM as well as grip editing makes the handling for my custom objects unnecessarily complicated.
Hence I'm posting my solution to disabling this function for my objects, I don't know if its the best way, but it works.
In your AcApDocManagerReactor::documentLockModeChanged handler you can use something like this:
if (_tcsicmp(pGlobalCmdName, _T("OLEDRAGDROP")) == 0 ||
_tcsicmp(pGlobalCmdName, _T("DROPGEOM")) == 0 ||
_tcsicmp(pGlobalCmdName, _T("DRAGENTER")) == 0)
    // Prevent objects from being dragged
    for (int i = 0; i < aLastSelectionArray.length(); i++)
        AcDbObjectId objId = aLastSelectionArray[i];
	MyObject* pObj = IsMyObject(objId);
        if (pObj != NULL)
            this->veto();
            break;
Accepted solutions (3)
Replies (63)
chungenlin45254
Observer
Observer
Hi Kyudos! Is there any posibility to have a 2012 compatible version? 🙏
Kyudos
I can't build it without the ObjectARX 2012 SDK - and I can't find a working download link. It doesn't appear to be on AutoDesk's servers anymore.
If you can find a link I can make it.
Alexander.Rivilis
https://download.autodesk.com/esd/objectarx/2012/ObjectARX_2012_Win_64_and_32Bit.exe
Facebook | Twitter | LinkedIn
Expert Elite Member
Kyudos
Thanks Alexander - I tried several of your other links (in other posts) and none of them seemed to be active!
Alexander.Rivilis
@Kyudos
Some years ago link begin with http: and now begin with https:
Expert Elite Member
Kyudos
@chungenlin45254 Untested, but should work.
chungenlin45254
Observer
Observer
sorry for replying so late!
I've tried to install it but it says the following,
"disabledragdrop.arx is incompatible with this version of AutoCAD.
AcRxDynamicLinker failed to load "
I've found some other versions of ObjectARX SDK provided by Alexander in the link below.
Some of them are also compatible with autocad 2012. I'm not sure if this will help.
Thank you so much.
Kyudos
I don't have a 2012 version of AutoCAD, so I can't really test this I'm afraid. Did you try both the debug and release versions?
chungenlin45254
Observer
Observer
I'm afraid so.
I've tried both the debug and release versions and they all failed to load...
CDM2424
Thanks for doing this! However, it doesn't appear to work. I had used it on 2020, and it worked flawlessly. Now with the 2023 version of CAD and the 2023 version of your arx, it doesn't seem to work at all. No errors in the command line either.
Kyudos
Hmmm...it works fine here (in Version T.181.0.0 AutoCAD 2023.1.4).
There's not much that can go wrong with it really, so I'm not sure what to suggest.
What do you see on the command line when you APPLOAD it? It should look like this:
Command: APPLOAD
Available commands:
DISABLEDD : disable drag and drop
ENABLEDD  : enable drag and drop
ENABLEDO : enable drag override
DISABLEDO  : disable drag override
DisableDragDrop.arx successfully loaded.
CDM2424
Appreciate the fast response.
I see the same thing.
Command: APPLOAD
Available commands:
DisableDragDrop2023.arx successfully loaded.
My CAD version.
Kyudos
Does it make a difference if you load it into the vanilla AutoCAD that underlies your Civil 3D? (I don't have C3D on my machine ATM so can't test it)
CDM2424
It doesn't work in vanilla either.
Kyudos
Neither of the functions?
CDM2424
Ok.... So.... I'm dumb. I forgot that I had previously added the command to "acaddoc.lsp"... I did this a while ago and this made me thing the commands were already enabled on startup straight from the arx.
I added it back as a startup command, and all is well. Thank you so much for your quick replies and for helping me through my own stupidity haha.
Kyudos
Haha! No problem. I find I often use the "ask on the forum" technique to solve problems. That is, you bash your head against something for hours/days, then ask on a forum about it, and subsequently and immediately solve it and have to answer your own forum question 😉
CDM2424
Haha, so true. I knew it had to be a simple solution. Sometimes I just get in my own way. Thanks again for all your help!!
jan.bartlomiejczyk
Community Visitor
Community Visitor
Hi, i know that this forum is for AutoCAD users, but in my new work i've got GstarCAD on my computer and very anoying problems with DROPGEOM . Gstar is not working with ARX files but GRX instead. I saw this video https://www.youtube.com/watch?v=HFAHoAOd1YY about changing ARX to GRX and it looks easy to do but not for an Architect who doesnt know anything about programing :D. Could you please help me and post the GRX file by chance?
jan.bartlomiejczyk
Community Visitor
Community Visitor
Hi, i know that this forum is for AutoCAD users, and i used Autocad for years, but now in my new work i've got GstarCAD and anoying problems with DROPGEOM. Gstar is not working with ARX but the GRX instead. I saw this video https://www.youtube.com/watch?v=HFAHoAOd1YY about how to change ARX to GRX and it looks easy but not for an Architect who doesnt know anything about programing :D. Could you please help me and post the GRX file by chance?
