create a command with parameter
Dear All,
I want transmit a outside parameter to CAD, my thinking is like following :
//outside code
class xxxxx
//outside code
string parameter="ParameterToTransmit";
document acdoc.SendCommand("MyCommand ",ParameterToTransmit😞
//CAD command
 [CommandMethod("MyCommand ")]
        public static void MyCommand (ParameterToTransmit)
But i don't know how to make a command with parameter .
Is  it possible to create a command with parameter ?
Or is  it have other solution?
moogalm
Autodesk Support
Autodesk Support
Dear Sir:
I can't open your link, and i got a solution in net forums, but thank you very much also.
https://forums.autodesk.com/t5/net/make-a-command-with-parameter/m-p/7179108#M53965
tbrammer
If you create a new ARX with the ObjectARX-Wizard, it will contain a lisp command called "MyLispFunction".
You find the implementation in acrxEntryPoint.cpp:
	static int ads_MyLispFunction () {
		struct resbuf *args =acedGetArgs () ;
		// Put your command code here
		acutRelRb (args) ;
		// Return a value to the AutoCAD Lisp Interpreter
		// acedRetNil, acedRetT, acedRetVoid, acedRetInt, acedRetReal, acedRetStr, acedRetPoint, acedRetName, acedRetList, acedRetVal
		return (RTNORM) ;
If you enter this command in AutoCAD:     (mylispfunction "abc" 10 3.141 123456789)
args will be a resbuf list with the four arguments.
A different approach could be to implement a "normal" command that calls acedGetString(TRUE,NULL,argline) to retrieve arguments from the commandline. Than you have to parse argline yourself.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Thank you very much
