Hi All,
We have used ObjectARX 2014 and developed some custom functionalities and have used them in AutoCad 2014. Now we would like to upgrade to AutoCad 2017. Do we have to recompile again. If yes could we please know the process of recompilation as we are really new to this?
We have also did some menu customization ( added new menus of our own ) and used Visual Studio 2012 to build it ( Some of these menu options are using functions in ObjectARX ). For those to work in AutoCad 2017 should we again do a build in Visual Studio 2015?
Thanks in Advance
Abhilash D K
Please read ObjectARX 2017 SDK\Docs\readarx.chm file: Release Notes
Facebook | Twitter | LinkedIn
Sorry but without full solution I can not help you.
First of all, the first error MSB8020 says you have a problem with your Visual Studio 2015.
Visual Studio 2015 uses the v140 Platform Toolset, if it dosn't find it, this is a VS problem, take a look here:
The next 2 errors are porting errors:
int acedGetString(int cronly, const ACHAR * prompt, ACHAR * result); and int acedCommand(int rtype, ... /*variable_arg_list*/); has changed to int acedGetString(int cronly, const ACHAR * prompt, ACHAR * result, size_t bufsize); and int acedCommandS(int rtype, ...);
Hi BerndCuder8196,
I am trying to resolve the issue with VS 2015.
I Went to Project->Properties->General and PlatForm Tooset is set to Visual Studio 2015 (v140). But still it gives error. I have even checked VCTargetsPath in regedit.exe it is set to v140. Still I am getting Build Tools not found error. Not able to resolve the Build Tools issue. I will keep looking into it 😞
Regarding the other errors: I changed the function signatures it cleared most of the errors.
Another error identifier "MustSwitchTo_acedCommandC_or_acedCommandS" is undefined in line acedCommand(RTSTR,L"setvar",RTSTR,L"filedia",RTSHORT,0,RTNONE);
Here I should change acedCommand to either acedCommandC or acedCommandS right? ( I Changed this and got rid of many errors )
I am getting Too Few Arguments in this line acedGetString(0,L"Do you wish to convert now? [Y/N] >",result); The same with ads_getstring(). I will look into the acedGetString() method in ObjectARX 2017 and check the number of arguments.
Thanks a million.
Abhilash D K
