Convert existing ARX project to CPP CLI
Hi all,
i have a arx project, which is completely written in C++. Now i need to convert this project to mixed mode C++ CLI. I Changed "Common Language Runtime Support" to "Pure MSIL Common Language Runtime Support (/clr:pure)" in project settings. Then I included the necessary header files in stdafx.h. Then wrapped the DllMain by #pragma managed(push, off). I build the arx it success fully builds. The problem is when i load usng AppLoad it hangs. While debugging, the dwebugger detects Loader Lock. I made some mistakes during convertion. is there any document, that describe how to convert Simple MFC Arx to C++ CLi Mixed mode ARX? Any help is appreciated.
Thanks in advance
Prem Kumar U
If you intend to continue using unmanaged code, instead of converting your
entire project to managed, just add your managed code in separate project
files and set only those files as managed.
Owen Wengerd
President, ManuSoft <>
VP Americas, CADLock, Inc. <>
"premkumaru" wrote in message news:[email protected]...
> Hi all,
> is appreciated.
> Thanks in advance
> Prem Kumar U
I don't think you can have mixed managed code in a project that marked as /cli pure, you need to use /clr
To resolve the load lock issue, try using /NOENTRY .. in Linker->advanced->no entry point
One last thing, is that a mixed-mode dll is loaded via NETLOAD, rather than
as a standard ARX dll is loaded (or add MANAGED=1 to the application's
registry key for demand-loading).
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
Hi all,
Thanks in advance
Prem Kumar U
{quote}
The problem is when i load usng AppLoad it hangs...
{quote}
Mixed-mode dlls are managed dlls, and must be loaded
as such (using the NETLOAD command, or by adding
MANAGED=1 to the application's registry entry).
Hi all,
Thanks in advance
Prem Kumar U
Hi All,
Thank you for your responses. Now my Arx works when i put /NoEntry option and loaded via Appload command.
