ObjectARX
Compile arx for older version Autocad
1 REPLY 1
sizy458
445 Views, 1 Reply
For compil arx for Autocad 2012 i specified directory objectarx 2012 (inc header file and lib file).
When i compile a arx application for Autocad 2012 (old version) with VS2017 with platform toolset vs90 it's OK.
When i compile a arx application for Autocad 2012 (old version) with VS2017 with platform toolset vs141 ,
Autocad show warning message 'arx is not compatible with version autocad' ....
How compile arx for Autocad 2012 with platform toolset vs141 ?????
Thank.
1 REPLY 1
Alexander.Rivilis
in reply to: sizy458
@sizy458 wrote:
... How compile arx for Autocad 2012 with platform toolset vs141 ????? ...
It's impossible. And even if the application was succeeded built, it would be incompatible with AutoCAD 2012 due to a different version of MS++ Runtime.
Facebook | Twitter | LinkedIn
Expert Elite Member
Forma Design Contest
