Command icons next to command
karl.sch1983
Message 1 of 1
karl.sch1983
I have built my ribbon using .Net runtime ribbon api. I am unsuccessful in displaying the icons next to the command at command line, although the ribbon works great with all the icons. I started a post in .Net to see if there was a way to do this. Meanwhile, does anyone know if there is anything in objectARX to achieve this. I do not want to build a cuix (with code or manually) and continue building the ribbon at runtime. Can someone confirm that I am out of luck, unless taking the cuix route. Thanks for all your help.
Replies (0)
