ObjectARX
Cancel LISP command from ARX
3 REPLIES 3
karl.sch1983
197 Views, 3 Replies
I have a reactor setup as follows
void CmdEdtrReactor::commandWillStart(const ACHAR* cmdStr)
     if (wcscmp(cmdStr, L"(C:MYLSPTEST)") == 0)
     this->veto();
However, the LISP command continues to execute. I can step through the debugger and see that the reactor is called and command matched, and this->veto is called. But after that the LISP continues to execute? Does anyone know if there is a better way to cancel a LISP command from ARX. Thanks for your help.
EDIT: I even tried this option, but no difference.
3 REPLIES 3
Method veto() may be called only from AcApDocManagerReactor::documentLockModeChanged event:
https://help.autodesk.com/view/OARX/2023/ENU/?guid=OARX-RefGuide-AcApDocManagerReactor__veto
But I am not sure that this method can help with cancel lisp-command.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Thanks @Alexander.Rivilis , for a moment there I thought we have the solution, but your suspicion is right. The veto command still does not recognize the LISP command for some reason. I can get in the reactor event and veto gets called but no affect on LISP command.
I have decided to go alternate route and get rid of the lisp altogether so I am only dealing with ARX modules. Although I would like to know if someone has come across this, and if so, what did they do instead of migrating LISP to ARX. Thanks again for looking into it.
Try:
acDocManager->sendStringToExecute(curDoc(), L"\x03\x03");
// or other method
acedPostCommand(L"\x03\x03");
Expert Elite Member
”Boost
