Can't find or load the QT platform plugin “windows”
Message 1 of 8
I tried to make an installer for my plugin, which is created for AutoCAD 2016 using QT 5.3.
-- It work perfectly on the development computer, but when I tried to install it somewhere else it give me the following message:
             ~~This application failed to start because it could not find or load the Qt platform plugin "windows".
-- I have already installed the QT plateforms as follows:
    ./contents/
          myPlugin.arx
          icudt53.dll
          icuin53.dll
          icuuc53.dll
          libEGL.dll
          Qt5Core.dll
          Qt5Gui.dll
          Qt5Nework.dll
          Qt5Quick.dll
          Qt5Widgets.dll
          platforms/qwindows.dll
-- I also define the runtime paths in the file (PackageContents.xml) as below:
<?xml version="1.0" encoding="utf-8"?>
<ApplicationPackage SchemaVersion="1.0" AutodeskProduct="AutoCAD" Name="StartupCommandTest" Description="Sample showing usage of StartupCommand parameter" AppVersion="1.0.0" ProductType="Application" AppNameSpace="appstore.exchange.autodesk.com" Author="xxxxxx">
  <CompanyDetails Name="XXXXXX" Url="www.xxxxx.com" Email="xxx@xxxx.com" />
  <Components>
    <RuntimeRequirements SupportPath="./Contents/; ./Contents/platforms/" OS="Win64" Platform="AutoCAD*" SeriesMin="R19.0" SeriesMax="R29.0" />
    <ComponentEntry AppName="MyPlugin.arx" ModuleName="./Contents/myPlugin.arx">
    </ComponentEntry>
  </Components>
    <Components Description="CUI">
    <RuntimeRequirements SupportPath="./Contents/Resources/" OS="Win64" Platform="AutoCAD*" SeriesMin="R19.1" SeriesMax="R29.1" />
    <ComponentEntry AppName="myPlugin.cuix" Version="1.1.0" ModuleName="./Contents/myPlugin.cuix"/>
  </Components>
</ApplicationPackage>
--  can anyone help? Thank you in advance.
Replies (7)
Message 2 of 8
augusto.goncalves
Can you install Process Monitor to determine what is missing? That should help you identify where the system is looking for those DLLs
https://technet.microsoft.com/en-us/sysinternals/processmonitor.aspx
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Message 3 of 8
cmurdo2003
Just had the same issue with 3ds Max 2018, probably associated with the Civil 3d plugin but I'm not sure. Currently following the only info I can find on this and re-installing 3ds MAx.
Message 4 of 8
Having this problem with revit 2019.
The problem is that it is recurring, and the temp. fix is reinstalling.
Message 5 of 8
I installed the QT library on my Windows 10 pc and rebooted, and was then able to download parts from autodesk-fusion.partcommunity.com/3d-cad-models/ into Fusion 360.
Message 6 of 8
Please provide the qt library link, I have the same error
Message 7 of 8
Hi
Go to https://www.qt.io/download and scroll down to the open source download.
Good luck
Michael
Message 8 of 8
What to choose from the checkboxes?
