ObjectARX
AcDbCurve::createFromAcGeCurve crash
4 REPLIES 4
chunyuran
675 Views, 4 Replies
It happend when offsetting spline. But it's ok when offsetting line, polyline, circle and arc. Any ideas! Thanks.
ads_point pt;
ads_name ename;
if (acedEntSel(NULL, ename, pt) != RTNORM) return;
AcDbObjectId id;
acdbGetObjectId(id, ename);
AcDbEntityPointer pent(id, AcDb::kForRead);
pent.openStatus();
AcDbCurve* psp = AcDbCurve::cast(pent);
if (psp == NULL) return;
AcGeCurve3d* pGeCurve = NULL;
psp->getAcGeCurve(pGeCurve);
pent->close();
double offsetdist = 100.0;
AcGeVoidPointerArray arr;
pGeCurve->getTrimmedOffset(offsetdist, AcGeVector3d::kZAxis, arr, AcGe::kExtend);
delete pGeCurve;
pGeCurve = NULL;
AcAxDocLock lock;
for (int i = 0; i < arr.length(); ++i) {
AcGeCurve3d* pCurve = (AcGeCurve3d*)arr.at(i);
AcDbCurve* pNewcurve = NULL;
AcDbCurve::createFromAcGeCurve(*pCurve, (AcDbCurve*&)pNewcurve);
delete pCurve;
pNewcurve->setColorIndex(1);
// append to database
AcDbDatabase* pdb = acdbHostApplicationServices()->workingDatabase();
AcDbObjectId curid = pdb->currentSpaceId();
AcDbBlockTableRecordPointer pbtr(curid, AcDb::kForWrite);
pbtr.openStatus();
AcDbObjectId newid;
pbtr->appendAcDbEntity(newid, pNewcurve);
pNewcurve->close();
4 REPLIES 4
tbrammer
in reply to: chunyuran
The problem is that AcDbCurve::createFromAcGeCurve(*pCurve, pNewcurve)  returns eInvalidInput for (some?) splines and leaves pNewcurve==NULL. You should always check the Acad::ErrorStatus!
Here is a possible workaround:
void cmdTestOffsetSpline()
	ads_point pt;
	ads_name ename;
		return;
	AcDbObjectId id;
	pent.openStatus();
	Acad::ErrorStatus es = psp->getAcGeCurve(pGeCurve); //TB check ErrorStatus!
	pent->close();
	if (es || !pGeCurve) {  //TB check ErrorStatus!
		acutPrintf(L"\ngetAcGeCurve(crv)=%s, crv=%x", acadErrorStatusText(es), pGeCurve);
		return;
	delete pGeCurve;
	pGeCurve = NULL;
	AcAxDocLock lock;
		if (!pCurve)
			continue;
		AcGe::EntityId type = pCurve->type();
		es = AcDbCurve::createFromAcGeCurve(*pCurve, pNewcurve);
		if (!es) //TB check es! eInvalidInput is returned for splines!
			delete pCurve;
		else {
			if (type == AcGe::kCompositeCrv3d)  {
				AcGeNurbCurve3d* pFinalNurb = NULL;
				AcGePoint3d ptNurbEnd, ptEnd, ptStart;
				AcGeCompositeCurve3d *ccrv = (AcGeCompositeCurve3d*)pCurve;
				AcGeVoidPointerArray curveList;
				ccrv->getCurveList(curveList);
				for (void* vp : curveList)
					AcGeNurbCurve3d *pNurb = NULL, *pTmpNurb = NULL;
					AcGeCurve3d* crv = (AcGeCurve3d*)vp;
					type = crv->type();
					if (type != AcGe::kNurbCurve3d) {
						double epsilon = AcGeContext::gTol.equalPoint();
						pTmpNurb = pNurb = new AcGeNurbCurve3d(*crv, epsilon);
					else
						pNurb = (AcGeNurbCurve3d*)crv;
					if (!pFinalNurb) {
						pFinalNurb = pNurb;
						if (!pTmpNurb)
							crv = NULL; // don't delete crv!
					else {
						if (pNurb->hasStartPoint(ptStart) && (ptStart==ptNurbEnd)) {
							pFinalNurb->joinWith(*pNurb);
							if (pFinalNurb->hasEndPoint(ptEnd))
								ptNurbEnd = ptEnd;
						ptNurbEnd = ptEnd;
					if (crv)
						delete crv;
				if (pFinalNurb) {
					AcDbCurve* segment=NULL;
					es = AcDbCurve::createFromAcGeCurve(*pFinalNurb, pNewcurve);
					delete pFinalNurb;
		if (pNewcurve)	{
			pNewcurve->setDatabaseDefaults(pdb);
			pNewcurve->setColorIndex(1); {
				pbtr.openStatus();
				AcDbObjectId newid;
			pNewcurve->close();
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
tbrammer
I played a bit with the function using epsilon=0.1 which reduces the number of control points. But the resulting spline causes a crash in AcDbCurve::createFromAcGeCurve(*pCurve, pNewcurve) if I try to apply an offset to it.
This looks like a bug in AutoCAD. The drawing I used is attached. I started with the black spline. With epsilon=0.1  the function created the red spline. This in turn caused a crash. Everything seems to be fine with the red spline.
chunyuran
in reply to: tbrammer
Thanks for your reply, tbrammer. Your code is very enlightened to me.
I tested on some random drawed spline in AutoCAD 2020. The first "AcDbCurve::createFromAcGeCurve" just crashed, not return anything like eInvalidInput.
Another thing in my case is that the type of AcGeCurve3d after "getTrimmedOffset" is always kOffsetCurve3d, and constructing a AcGeNurbCurve3d from AcGeOffsetCurve3d crashed also.
I'll try it again with a higher AutoCAD version.
tbrammer
That's exactly what I found in my tests with AutoCAD 2022. But I haven't tested with 2023.
I suppose there is a severe bug with spline offset curves. Autodesk engineers should have a look at this.
Forma Design Contest
