Zoom and pan changed.
Message 1 of 11
There is any way to get an event when the user change Autocad screen view
(using zoom, pan, or any arx api).
Aragao
Replies (10)
Message 2 of 11
Paulo,
There are two System Variables called VIEWCTR and VIEWSIZE that are affected
when you PAN, ZOOM or change your current view.
If you trap sysVarChanged() Editor reactor notification you can find out if
both or one of them have changed.
Fernando.
"Paulo Aragao" wrote in message
news:BDC393524845890EDD542096AF1AA8F4@in.WebX.maYIadrTaRb...
> Hi,
> Thanks,
> Aragao
Message 3 of 11
"Fernando Poinho Malard" wrote in message
news:39BD9ABB58E84285A4BADB516F951B3E@in.WebX.maYIadrTaRb...
> Paulo,
affected
if
I'm afraid not. sysVarChanged() does not report changes
to many system variables, including these two. I would
assume that's because both of those sysvars are viewport
specific, so they have different values in each viewport.
Message 4 of 11
Hi Fernando,
I have tried it, but Editor Reactor and Database Reactor don´t fire any
event when the user pan and zoom.
"Fernando Poinho Malard" escreveu na mensagem
> Paulo,
affected
if
> Regards,
> Fernando.
> > Hi,
view
> > Thanks,
> > Aragao
Message 5 of 11
Paulo,
I think these operations always fire commandStart/End notifications.
So, you can cache these variables values on commandStart() and check if they
have changed on commandEnd().
This is very dirty but I think it will work.
Fernando.
news:9C5B7F7C8C93E1021E6B3E1A71656FAC@in.WebX.maYIadrTaRb...
> Hi Fernando,
> > Paulo,
> affected
> if
> > Regards,
> > Fernando.
> > > Hi,
> view
> > > Thanks,
> > > Aragao
Message 6 of 11
news:4295F9D43C21ABF766FD36114E6FE0CC@in.WebX.maYIadrTaRb...
> Paulo,
they
For Zoom, Pan, View/Restore and so forth, it will, but
there is no notification fired when the user pans the
drawing using the scroll bars.
Message 7 of 11
Really there is no notification using scroll bars.
"Tony Tanzillo" escreveu na mensagem
news:1E0E85D41DE1F2D469FF2BC8B5BD2D1F@in.WebX.maYIadrTaRb...
> > Paulo,
> they
Message 8 of 11
Tony,
Can we trap OnScroll() event from AutoCAD's View?
"Tony Tanzillo" wrote in message
> > Paulo,
> they
Message 9 of 11
Maybe this is not a complete solution. Like Tony said, we have scrooll bar
problem.
AutoDESK have implemented this feature on AGISDS product for AutoCAD MAP
to load and unload acad entities if the user is inside or outside a defined
range zoom scale factor.
> Paulo,
they
> Regards,
> Fernando.
> > Hi Fernando,
> > > Paulo,
> > affected
out
> > if
> > > Regards,
> > > Fernando.
> > > > Hi,
> > view
> > > > Thanks,
> > > > Aragao
Message 10 of 11
Paulo,
This was made to improve performance to load only what the drawing really
needs to show.
Some time ago I saw a LISP routine that divide a drawing on several DWG by a
grid. If user goes out a grid the application detects the next grid square
and load it on AutoCAD. It works very nice and its idea is very good. This
way AutoCAD runs fast and the user can navigate int theory on any size map.
Fernando.
news:1B885D4E76C9072C1A04A799E2C2A08B@in.WebX.maYIadrTaRb...
> Hi,
> problem.
defined
> > Paulo,
> they
> > Regards,
> > Fernando.
> > > Hi Fernando,
any
> > > > Paulo,
> > > affected
> out
> > > if
> > > > Regards,
> > > > Fernando.
> > > > > Hi,
screen
> > > view
> > > > > Thanks,
> > > > > Aragao
Message 11 of 11
God idea.
But, on my case, I am using AGISDS.
So, I have all information (spatial and non-spatial) stored on Oracle
Database.
Using AGIDS I can load any portion of the database on my drawing and I can
give range zomm scale factor to each layer, so every information on a layer
is showed when the drawing is inside
the range.
But I have to Implement to Raster images, because the user can overlap the
raster image with autocad entities.
Aragao
news:BDF4A4DF5914F5BE6841CA95F2236939@in.WebX.maYIadrTaRb...
> Paulo,
> needs to show.
a
map.
> Regards,
> Fernando.
> > Hi,
bar
> > problem.
> defined
> > > Paulo,
if
> > they
> > > Regards,
> > > Fernando.
> > > > Hi Fernando,
> any
> > > > > Paulo,
are
> > > > affected
find
> > out
> > > > if
> > > > > Regards,
> > > > > Fernando.
> > > > > > Hi,
> screen
> > > > view
> > > > > > Thanks,
> > > > > > Aragao
