write and read from a global vector variable
hello,
I declared a global vector variable, and it looks like writing to the
vector is never a problem, but reading is sometimes...
I got a class MyClass. The objects of that class are put in a vector:
vector MyContainer. (global variable, is cleared at the
beginning of the program by MyContainer.clear())
When I want to put an object in the class, this is no problem, but when I
read back from the container, something goes wrong.
void Import()
// ... get the parameters needed for the new object...
MyClass NewObject(/*..parameters..*/);
MyContainer.push_back(NewObject);
int Number = MyContainer.size() - 1;
// the number of the element just added
// ... some other operations on the object in the container
acutPrintf("\nObject Name: %s", MyContainer[Number].GetName());
// prints the name to the Autocad command line
// this line doesn't cause any problem.
// acutPrintf("\nNumber of objects so far: %s", MyContainer.size());
// at this line, the program crashes... 😞
// if I skip this line, the program continues
for (int i=0; i acutPrintf("\n\t%s", MyContainer.GetName());
// this line doesn't cause any problem either....
return;
It's very strange that at first, it works to enter the container, and
suddenly not anymore...
The errormessage that appears when the program crashes is always
something like this: "FATAL ERROR: Unhandled access violation reading
0x4d64696a Exception at 481d55h".
I think it has something to do with the memory use, but I cannot find the
problem... :(:(
Does anyone know what can be wrong?
Thanks a lot!
jeroen
hold your light, Eleven
acutPrintf() is looking for a string '%s' 🙂
| Byron Blattel
| CADwerx---Applications for AutoCAD
| Autodesk Registered Developer
| email: byron@cadwerx.net
| web site: http://www.cadwerx.net
Byron Blattel wrote in news:CFN373165356287963
@discussion.autodesk.com:
(EDITED)... silly me 🙂
but how can I actually solve this??
(EDITED)....silly me 🙂
thanx!
Use %d for integers.
"Jeroen Henckaerts" wrote in
message news:A66D0CFC8FD13EDA1BCE9DFA1EAA01C3@in.WebX.maYIadrTaRb...
> (EDITED).. silly me 🙂
