Why comes error"eNotImpementedYet" and how to deal with it?
Paciguard
Message 1 of 11
Paciguard
Hello, everybody:
While I try to apply intersectwith function with two line in .NET, just catch the exception as "eNotImplementedYet", why it comes and how to deal with that?
Thanks and BR,
Replies (10)
Message 2 of 11
tbrammer
You should ask .NET questions in the .NET forum. Add a sample (code + drawing) to reproduce your problem if possible.
Do your lines really intersect? Are they lying in the same plane?
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Message 3 of 11
Paciguard
Thanks for your reply. Cause I just try ARX not BRX or TX, so I post here. About my two lines, they are very simple line, and whatever they have intersect point, the intersectwith function should work and return a result. But as for this case, I can not even to apply the function. So I confused about where is not implemented for the function.
Message 4 of 11
tbrammer
I suppose we are talking about AcDbLines, right? Or AcGeLine3d? AcGeLine2d?
Could it be that the lines in question have a (custom) class that is derived from AcDbLine?
Can you check this using LPCTSTR pcClassName = pLine->isA()->desc()
Or try to call pLine->AcDbLine::intersectWith(pOtherLine) explicitely. Does it help?
A few lines of sample code and a DWG would really help to clarify your issue.
Message 5 of 11
Paciguard
OK.Thans very much for your reply, Sir. My line is Line of Autocad.databaseservices.Line. And part of my codes as follows:
Dim Db as database
Db.readdwgfile("myfile",FileOpenMode.OpenForReadandWriteNoShare, False,"")
dim Btr as BlockTableRecord=Db.CurrentSpaceId.GetObject(OpenMode.ForWrite)
dim Bt as BlockTable=Db.BlockTableId.Getobject(OpenMode.ForWrite)
Brt.Id.Getobject(OpenMode.ForWrite,True,True)
Bt.Objectid.Getobject(OpenMode.ForWrite)
Dim Tr as TransactionManager=Db.TransactionManager
dim Linb as line=nothing
dim acLine as line=nothing
For each ObjId as ObjectId in Btr
dim Enta as Entity=Tr.Getobject(ObjectId,OpenMode.ForWrite)
if Typeof Enta Is Line then
if Enta.ColorIndex=2 then
Linb=Tr.Getobject(Enta.ObjectId,OpenMode.ForWrite)
end if
if Enta.ColorIndex<>2 then
acLine=Tr.Getobject(Enta.ObjectId,OpenMode.ForWrite)
End if
End if
Next
dim Pta3d as Point3dCollection=New Point3dCollection
Linb.Intersectwith(acLine,Intersect.OnBothOperands,Pta3d,IntPtr.Zero,IntPtr.Zero)
if Pta3d.Count>0 then
messagebox "Find Point"
End if
and before that, I have two lines in my drawing, one is yellow, one is white.
Thanks and BR,
Message 6 of 11
tbrammer
Would you append "myfile.dwg" please?
Have you checked whether Linb and acLine are valid before  Linb.Intersectwith(acLine, ...)  ?
I wonder why you open all objects ForWrite. In general you should open objects ForRead if you don't need to modify them.
If ObjectId is a line with color 2 your code does:
  Enta=Tr.Getobject(ObjectId,OpenMode.ForWrite)
I'm not sure that this will be the case if you try to open the same Id twice ForWrite.
Message 7 of 11
OysteinW
If I read the VB code right, Linb, Enta and acLine is all the same object... So intersect with self is not supported on lines (which makes sense).
Message 8 of 11
tbrammer
No, they are different. Linb has ColorIndex=2 and acLine has ColorIndex<>2.
Enta iterates over all entities in the modelspace within the For-loop.
Message 9 of 11
OysteinW
You're right, they are not the same..
As the code stands though, we probably wouldn't reach the Linb.intersectWith statement at all as there are no calls to Db.TransactionManager.StartTransaction(), so we should get a eNoActiveTransactions exception on GetObject, if not running into a nullreference exception at line 2 unless VB.Net knows which constructor to call on Database.
Rewritten into C# and modified a bit, the code works:
            using (Database Db = new Database(false, true))
                Db.ReadDwgFile(@"D:\test.dwg", FileOpenMode.OpenForReadAndWriteNoShare, false, "");
                using(Transaction tr = Db.TransactionManager.StartTransaction())
                    BlockTableRecord Btr = tr.GetObject(Db.CurrentSpaceId,OpenMode.ForRead) as BlockTableRecord;
                    if (Btr != null)
                        Line Linb = null;
                        Line acLine = null;
                        foreach (ObjectId ObjId in Btr)
                            Entity Enta = tr.GetObject(ObjId, OpenMode.ForRead) as Entity;
                            if (Enta is Line)
                                if (Enta.ColorIndex == 2)
                                    Linb = tr.GetObject(Enta.ObjectId, OpenMode.ForRead) as Line;
                                if (Enta.ColorIndex != 2)
                                    acLine = tr.GetObject(Enta.ObjectId, OpenMode.ForRead) as Line;
                        try
                            Point3dCollection Pta = new Point3dCollection();
                            Linb.IntersectWith(acLine, Intersect.OnBothOperands, Pta, IntPtr.Zero, IntPtr.Zero);
                        catch (System.Exception error)
                            System.Windows.MessageBox.Show(error.StackTrace, error.Message);
                    tr.Commit();
Message 10 of 11
tbrammer
Ok. But does it work with Paciguard's DWG as well`? Maybe it contains custom objects derived from LINE.
I would suggest to rewrite the VB code like this:
dim Btr as BlockTableRecord=Db.CurrentSpaceId.GetObject(OpenMode.ForRead)
Brt.Id.Getobject(OpenMode.ForRead,True,True)
Dim yellowLine As ObjectId
Dim otherLine As ObjectId
REM find objectIDs of the lines
	dim Enta as Entity=Tr.Getobject(ObjectId,OpenMode.ForRead)
			yellowLine = ObjectId;
		else
			otherLine = ObjectId;
		End if
	End if
Next
REM open lines and intersect
Linb=Tr.Getobject(yellowLine,OpenMode.ForRead)
acLine=Tr.Getobject(otherLine,OpenMode.ForRead)
Changes in short:
+ Loop only stores the objectIDs of the lines and doesn't open them.
+ Open ForRead only instead of ForWrite
Message 11 of 11
Paciguard
OK. Thanks very much for your reply. I will try later.
