Visual C++ 6.0 & AutoCAD 2005
I noticed the objectarx sdk recommends c++ 7.0, can i use it with c++ 6.0 or do i need to upgrade my software?
You need to use VC++ 7.0 (that included in Visual Studio .NET 2002 to be clear) 'cause Autocad 2005 only is compatible with binaries compiled with this compiler version.
If you try to compile with VS .NET 2003 compilier you'll get an "Incompatible binary" error.
Furthermore you need .net framework to let your arx module to work properly.
Peace.
ZaZy
You dont need .Net framework, but its true you need VC++ 7.0 and only this version is compatible with Autocad 2004 & 2005. Regards Rex "zazy" schrieb im Newsbeitrag news:21005809.1099400934335.JavaMail.jive@jiveforum2.autodesk.com... > You need to use VC++ 7.0 (that included in Visual Studio .NET 2002 to be clear) 'cause Autocad 2005 only is compatible with binaries compiled with this compiler version. > If you try to compile with VS .NET 2003 compilier you'll get an "Incompatible binary" error. > Furthermore you need .net framework to let your arx module to work properly. > > Peace. > > ZaZy
You can use vc6.0 MSDEV.exe ,but the lib inc bin use vc7.0
