Using resource defined in MFC DLL project from ARXProject
Message 1 of 8
We use AutoCad Architect 2009 with ObjectARX 2009 and Visual Studio 2005 SP1.
We define in an ARX Project the function below :
void CSendingCommandsApp::AdskSendingCommands_TEST1(void)
CAcModuleResourceOverride temp;
CDisplay a;
a.Display();
In this function, we want to display a resource define in a MFC extension DLL.
void CDisplay::Display()
CString cs;
cs.LoadStringW(IDS_Hello);
AfxMessageBox(cs);
When we execute our command TEST1 in Autocad, we have an Assert in AfxWin1.inl :
_AFXWIN_INLINE HINSTANCE AFXAPI AfxGetResourceHandle()
{ ASSERT(afxCurrentResourceHandle != NULL);
return afxCurrentResourceHandle; }
Thank you for your help,
Replies (7)
Message 2 of 8
Is CDisplay::Display() defined in the .arx module? Did you use the
ObjectARX wizard to create your project skeleton?
Owen Wengerd
President, ManuSoft <>
VP Americas, CADLock, Inc. <>
Message 3 of 8
Hello Owen,
Tanks for your reply.
I've found a solution, and it's work fine!! But now, I've another problem when I try to load a DialogBoxe defined in my MFC dll...
To answer, your question, yes I use the ObjectARX wizard to create my project skeleton and The CDisplay::Display() method is defined in my MFC DLL module.
First, that is what I have done (if it could help someone else...) :
In my ARX module :
CDisplay a;
a.Display(acedGetAcadResourceInstance(), acedGetAcadFrame() );
In my MFC DLL module :
In the CDisplay.h file :
static HINSTANCE hInstanceSafe;
In the entry point of my MFC DLL module :
DllMain(HINSTANCE hInstance, DWORD dwReason, LPVOID lpReserved)
CDisplay::hInstanceSafe = hInstance;
In the CDisplay.cpp file :
HINSTANCE CDisplay::hInstanceSafe = NULL;
void CDisplay::Display( HINSTANCE h, CWnd* pParent )
AfxSetResourceHandle( hInstanceSafe );
CString cs;
cs.LoadStringW(IDS_Bonjour);
AfxMessageBox(cs);
AfxSetResourceHandle( h );
The Step2, and my real goal, is to display a DialogBoxe, defined in my MFC DLL module.
I've tried all solutions I've found on the net, but nothing work for me.
Now, when I call DoModal(), I have an Assert in objcore.cpp :
BOOL CObject::IsKindOf(const CRuntimeClass* pClass) const
ENSURE(this != NULL);
// it better be in valid memory, at least for CObject size
ASSERT(AfxIsValidAddress(this, sizeof(CObject)));
That is what I have done :
In my ARX module :
CDisplay a;
a.Display( acedGetAcadResourceInstance(), acedGetAcadFrame() );
In my MFC DLL :
CDlgBidon* pDlg = new CDlgBidon( pParent );
pDlg->DoModal();
pDlg->DestroyWindow();
delete pDlg;
/*CString cs;
AfxMessageBox(cs);*/
What's going wrong??
Thanks for your help,
Sophie D.
Message 4 of 8
Having this problem in debug builds, release builds, or both?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
wrote in message news:5961074@discussion.autodesk.com...
Hello Owen,
In my ARX module :
CDisplay a;
CString cs;
AfxMessageBox(cs);
In my ARX module :
CDisplay a;
In my MFC DLL :
pDlg->DoModal();
delete pDlg;
/*CString cs;
Sophie D.
Message 5 of 8
Hi Tony,
I've this problem on both debug and release builds.
Sophie.
Message 6 of 8
Elcom,
Have you added this macro prior to running you function?
myFunction()
MFC_RESOURCE_INIT;
do_it_now();
Regards Gary.
www.drcauto.com
Hello Owen,
module.
In my ARX module :
CDisplay a;
CString cs;
AfxMessageBox(cs);
DLL module.
In my ARX module :
CDisplay a;
In my MFC DLL :
pDlg->DoModal();
delete pDlg;
/*CString cs;
Sophie D.
Message 7 of 8
Hello Gary,
Thanks for your reply, but could you be more clear please? I don't understand what you suggest me to do. What is this macro MFC_RESOURCE_INIT? I don't find it.
Message 8 of 8
Sophie,
Sorry about that was one of ours!
I think your problem is here.
You don't appear to be initializing it!
Try this!
if (dwReason == DLL_PROCESS_ATTACH) {
_hdllInstance = hInstance;
// CDisplay initialization
CDisplay::SetDefaultResource(_hdllInstance);
Regards Gary.
www.drcauto.com
wrote in message news:5962236@discussion.autodesk.com...
Hello Gary,
I don't find it.
