SetTimer and KillTimer??
Message 1 of 9
in the below code i set a timer...but when i unload the timer keeps
going...whats wrong??
Jaime
// PropTimer.cpp : Initialization functions
#include "StdAfx.h"
#include "StdArx.h"
#include "resource.h"
#include "aced.h"
#include "adslib.h"
#include "time.h"
#include "windows.h"
#include "acutads.h"
#include "adsdef.h"
#include "acedads.h"
class AsdkCommandReactor;
HINSTANCE _hdllInstance =NULL ;
AsdkCommandReactor* cmdr = NULL;
// This command registers an ARX command.
void AddCommand(const char* cmdGroup, const char* cmdInt, const char*
cmdLoc,
const int cmdFlags, const AcRxFunctionPtr
cmdProc, const int idLocal = -1);
// NOTE: DO NOT edit the following lines.
//{{AFX_ARX_MSG
void InitApplication();
void UnloadApplication();
//}}AFX_ARX_MSG
//{{AFX_ARX_ADDIN_FUNCS
//}}AFX_ARX_ADDIN_FUNCS
// DLL Entry Point
extern "C"
BOOL WINAPI DllMain(HINSTANCE hInstance, DWORD dwReason, LPVOID
/*lpReserved*/)
if (dwReason == DLL_PROCESS_ATTACH)
_hdllInstance = hInstance;
} else if (dwReason == DLL_PROCESS_DETACH) {
return TRUE; // ok
class AsdkCommandReactor : public AcEditorReactor {
public:
virtual void commandWillStart(const char * cmdStr);
virtual void commandEnded(const char* cmdStr);
void AsdkCommandReactor::commandWillStart(const char* cmdStr)
if (strcmp(cmdStr,"PROPERTIES") == 0 )
acutPrintf("\nPROPERTIES IS OPEN\n");
VOID CALLBACK MyTimerProc(
HWND hWnd, // handle of CWnd that called SetTimer
UINT nMsg, // WM_TIMER
UINT nIDEvent, // timer identification
DWORD dwTime // system time
struct resbuf *Result = NULL,*cmdlist;
cmdlist = acutBuildList(RTSTR,"PROPERTIESCLOSE",RTNONE);
acedInvoke(cmdlist, &Result);
acutRelRb(cmdlist);
acutPrintf("Hello %s",nMsg);
UINT IDT;
void AsdkCommandReactor::commandEnded(const char* cmdStr)
acutPrintf("\nClose Properties Next");
UINT uResult;
uResult = SetTimer(NULL,IDT,5000,(TIMERPROC) MyTimerProc);
if (uResult == 0)
acutPrintf("\nNo Timer Is Available.");
// ObjectARX EntryPoint
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* pkt)
switch (msg) {
case AcRx::kInitAppMsg:
// Comment out the following line if your
// application should be locked into memory
acrxDynamicLinker->unlockApplication(pkt);
acrxDynamicLinker->registerAppMDIAware(pkt);
InitApplication();
break;
case AcRx::kUnloadAppMsg:
break;
return AcRx::kRetOK;
// Init this application. Register your
// commands, reactors...
//{{AFX_ARX_INIT
//}}AFX_ARX_INIT
// TODO: add your initialization functions
acutPrintf("\nProgram Loaded\n");
cmdr = new AsdkCommandReactor();
acedEditor->addReactor(cmdr);
// Unload this application. Unregister all objects
// registered in InitApplication.
//{{AFX_ARX_EXIT
//}}AFX_ARX_EXIT
// TODO: clean up your application
acutPrintf("\nProgram Unloaded\n");
acedEditor->removeReactor(cmdr);
delete cmdr;
KillTimer(NULL, IDT);
// This functions registers an ARX command.
// It can be used to read the localized command name
// from a string table stored in the resources.
cmdLoc,
cmdProc, const int idLocal)
char cmdLocRes[65];
// If idLocal is not -1, it's treated as an ID for
// a string stored in the resources.
if (idLocal != -1) {
// Load strings from the string table and register the
command.
::LoadString(_hdllInstance, idLocal, cmdLocRes, 64);
acedRegCmds->addCommand(cmdGroup, cmdInt, cmdLocRes,
cmdFlags, cmdProc);
} else
// idLocal is -1, so the 'hard coded'
// localized function name is used.
acedRegCmds->addCommand(cmdGroup, cmdInt, cmdLoc, cmdFlags,
cmdProc);
Replies (8)
Message 2 of 9
"Jaime" wrote in message
news:22C9763E1A36F7FBAE7B1649A6974FC2@in.WebX.maYIadrTaRb...
You'll have to excuse my not answering your question,
but I'm at a loss to understand what your code is
attmpting to do.
For one thing, you're trying to execute a command
(PROPERTIESCLOSE) using acedInvoke(), which doesn't
execute commands.
acedCommand() executes commands, but you can't use
it from a timer callback.
I really don't know think I can go further without
knowing what it is your code is attempting to do.
Message 3 of 9
Ok try this, see SetTimer() help
You write :
>UINT IDT;
> UINT uResult;
> if (uResult == 0)
Correction :
IDT = SetTimer(NULL,0,5000,(TIMERPROC) MyTimerProc);
if (IDT == 0)
Here is SetTimer Doc (from MSDN) :
UINT SetTimer(
HWND hWnd, // handle of window for timer messages
UINT nIDEvent, // timer identifier
UINT uElapse, // time-out value
TIMERPROC lpTimerFunc // address of timer procedure
-----------------------------HERE IS UR MISTAKE -------------------------
nIDEvent
Specifies a nonzero timer identifier. If the hWnd parameter is NULL, this
parameter is ignored.
-----------------------------HERE IS WHAT U HAVE TO DO-------------
Return Values
If the function succeeds, the return value is an integer identifying the new
timer. An application can pass this value, or the string identifier, if it
exists, to the KillTimer function to destroy the timer.
If the function fails to create a timer, the return value is zero. To get
extended error information, call GetLastError.
Message 4 of 9
well at the moment all its tring to do is kill the timer 🙂
Message 5 of 9
sorry but youll have to use english to explain this.i dont understand why
your saying my "settimer" is wrong when that part of it works
and ive stared blankly at the msdn help files for serveal hours. (which is
where i got the examples im working from)
Message 6 of 9
thanks for the help..but i think i figured it out (at least it works anyway)
Jaime
Message 7 of 9
When "hwnd" parameter in SetTimer is NULL, you have to kill the timer by
returned ID.
E.g.
m_uTimerId = SetTimer(NULL, NULL, 5000, ,(TIMERPROC) MyTimerProc);
and in UnloadApplication function:
KillTimer(NULL, m_uTimerId);
MSDN Library says:
" If the hWnd parameter is NULL, second parameter (nIDEvent) is ignored."
You should declare m_uTimerId as global variable or (better) as data member
of class,
in member of which you call SetTimer.
Vladimir Kolesnikov.
news:f105210.4@WebX.maYIadrTaRb...
anyway)
> Jaime
Message 8 of 9
hi,
your settimer funktion only works, if there is a
ontimer (...) (mfc-code)
funktion in your code, which do something if your
timermessage
is fired.
regards
chris
Message 9 of 9
hi,
here is a litle peace of code, may it help's
chris
void SomeFunktion()
m_nTimer = SetTimer(1, 100, NULL); // 1/10 sec
void OnTimer(UINT nIDEvent)
TRACE0( " OnTimer() entered\n" );
if (nIDEvent == 1)//
Do something here = 0;
if (nIDEvent == 2)//
Do something here = 1;
if (nIDEvent == 3)
Do something here = 5;
