setCurrentLayoutId() crashes the second time around
Does anyone have any ideas about the following?
I have a custom object derived from AcDbPolyline. In a member function, it
initially creates its own layout, sets it current, and saves the ObjectId in
a member variable. When calling the same member function a second time, it
does not create another layout, of course, but when I try to set the
existing one current, it crashes: eWasOpenForWrite. Code/pseudo-code is
below. Note: It doesn't crash if I never go back to modelspace (i.e.
comment-out ...setTilemode(1)).
Thanks.
bool DCSDwgInfo::setup(bool edit)
AcDbLayout *pLayout;
AcApLayoutManager *pLayoutMan;
Acad::ErrorStatus es;
pLayoutMan=(AcApLayoutManager *)
acdbHostApplicationServices()->layoutManager();
if ((pLayout=pLayoutMan->findLayoutNamed("dcsLayout"))==NULL)
pLayoutMan->createLayout("dcsLayout",mLayoutId,mLayoutBlockTblRecId);
else
mLayoutId=pLayout->objectId();
es=pLayout->close();
*****It crashes here*******
pLayoutMan->setCurrentLayoutId(mLayoutId);
*****It won't crash if I comment out this line and never go back to
modelspace**********
acdbHostApplicationServices()->workingDatabase()->setTilemode(1);
**edit vertex points here**
acdbHostApplicationServices()->workingDatabase()->setLtscale(mScaleFactor);
acdbHostApplicationServices()->workingDatabase()->setPsltscale(true);
return true;
cadman,
Try to put the assertWriteEnabled() call at the beginning of your
DCSDwgInfo::setup() function.
Also, to do this, your object must be opened for write, is it opened?
Fernando.
"cadman" wrote in message
news:[email protected]...
it
in
it
> Thanks.
> else
> return true;
Fernando,
Yes, I am doing both of these (actually, I put assertWriteEnabled() in after
I posted the problem, and acdbOpenObject(...) is called by the calling
function). I am wondering if the AcDbLayout object is somehow been left
open for writing? Also, is there a way to tell *which* object
eWasOpenForWrite?
Thanks again.
"Fernando Malard" wrote in message
> cadman,
> Regards,
> Fernando.
