Secondary development of CAD, size_t redefinition error
1196756854
1196756854
使用visual studio2019+ObjectARX2021+AutoCAD2021进行的环境开发,选择项目模版为“ARX/DBX Project For AutoCAD 2021”,点击创建,选择MFC support选项为Extension DLL using MFC Shared DLL,点击Finish,在acrxEntryPoint.cpp界面下点击“本地Windows调试器”,然后出现C2371“size_t”:重定义;不同的基类型错误和C1189错误,不知道是怎么回事,应该怎么解决呢?(已在属性页将C/C++/代码生成/较小类型检查设置为否)。 The development environment uses Visual Studio 2019 + ObjectARX 2021 + AutoCAD 2021. The project template selected is "ARX/DBX Project For AutoCAD 2021". After clicking Create, the MFC support option is set to Extension DLL using MFC Shared DLL, and then Finish is clicked. In the acrxEntryPoint.cpp interface, when clicking on the "Local Windows Debugger", a C2371 "size_t": size_t redefinition error with different basic type and a C1189 error appear. I'm not sure what's wrong and how to fix it. (In the property page, the C/C++ > Code Generation > Type Check for Smaller Types has been set to No).
tbrammer
Regarding size_t: This type is defined in Visual Studio C runtime headers (in my case vcruntime.h) like this:
// Definitions of common types
#ifdef _WIN64
    typedef unsigned __int64 size_t;
#else
    typedef unsigned int     size_t;
#endif
 Could it be that you are mixing 32bit and 64bit headers?
The /RTC error can be fixed by adding
 #define _ALLOW_RTCc_IN_STL
at the beginning of your stdafx.h.
Or (like you did it) by setting [C/C++]->[Code Generation]->[Smaller Type Check] = No.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
