Run ARX code after AutoCAD is completely loaded
I have some ARX code that needs to be run one time after AutoCAD Map is
completely loaded. A reactor seems like the logical place for this code,
but I can't seem to find one for "AutoCAD has finished its incredibly long
initialization process."
Does anybody have any ideas?
Alan
You'll need to load one ARX at startup, and from the first kLoadDwgMsg in
that ARX issue a call to ads_queueexpr() to run an ADS command that the same
ARX defines. From the ADS command handler, load the second ARX that you
want loading after initialization is complete. 🙂
Owen Wengerd
President, ManuSoft ==> http://www.manusoft.com
VP Americas, CADLock, Inc. ==> http://www.cadlock.com
Owen,
Thank you for the information, but is loading a second ARX the only way? Is
there no way accomplish it within a single ARX?
Alan
"Owen Wengerd" wrote in message
news:5393072@discussion.autodesk.com...
Owen Wengerd
Alan:
> Is there no way accomplish it within a single ARX?
The ADS command handler can do something other than load another ARX
module. It sounds like that's what you're after. 🙂
Owen Wengerd
Thanks Owen! That seems to be working.
news:5394290@discussion.autodesk.com...
Alan:
Owen Wengerd
