Release VS. Debug
Release VS. Debug
Release VS. Debug
Can anyone tell me the difference between release
and debug version? Because I have this problem - I have this arx preject,
compile it in Debug configuration - it's ok, then try to build the
ReleaseMinDependancy configuration - it gives me a redefinition. First it was
__free  and __malloc, then it was a redefinition of my Interface (I am
writing a COM server):
size=2>E:\Vlado\#U.A.S.G\C++\VBExtend3\VBExtend3_i.c(38) : error C2370:
'LIBID_VBEXTEND3Lib' : redefinition; different storage
class
E:\Vlado\#U.A.S.G\C++\VBExtend3\VBExtend3.h(64) : see declaration of
E:\Vlado\#U.A.S.G\C++\VBExtend3\VBExtend3_i.c(41) :
error C2370: 'IID_ICurveX' : redefinition; different storage
class
E:\Vlado\#U.A.S.G\C++\VBExtend3\VBExtend3.h(73) : see declaration of
'IID_ICurveX'
E:\Vlado\#U.A.S.G\C++\VBExtend3\VBExtend3_i.c(44) : error
C2370: 'CLSID_CurveX' : redefinition; different storage
class
E:\Vlado\#U.A.S.G\C++\VBExtend3\VBExtend3.h(380) : see declaration of
'CLSID_CurveX'
Generating Code...
Error executing
cl.exe.
VBExtend3.arx - 3 error(s), 0
warning(s)
ICurveX is my interface, and VBExtend is the
project's name. Why don't I get these with the Debug version? What am I doing
wrong and any ideas where can I read about it or how to fix
it?
Blade
hello,
try to compile in just W32release, it may
work.
chris
When the ATL COM AppWizard generates the default project, it defines the
macro _ATL_MIN_CRT. This macro is defined so that you don't bring the C
Run-Time Library into your code if you don't need it.
Therefore, you need to remove the _ATL_MIN_CRT macro.
On your Project Settings, for Rease version, on C/C++ tab, choose
the General category, then remove _ATL_MIN_CRT from the
Preprocessor definitions edit box.
Aragao
class
class
'IID_ICurveX'
class
'CLSID_CurveX'
Generating Code...
Error executing
cl.exe.
warning(s)
it?
Blade
I don't know guys, but it's not it. This
ATL_MIN_CRT macro is set only for ReleaseMinSize and it doesn't matter if I
remove it or not. That is not it. The problem is that even if I comment out
these redefinitions, on build something uncomments them... Help
Blade
Aragao
release and debug version? Because I have this problem - I have this arx
preject, compile it in Debug configuration - it's ok, then try to build the
was __free  and __malloc, then it was a redefinition of my Interface (I
am writing a COM server):
class
class
'IID_ICurveX'
class
'CLSID_CurveX'
Generating Code...
Error executing
cl.exe.
warning(s)
doing wrong and any ideas where can I read about it or how to
fix it?
Blade
size=2>
Vladi,
Did you have checked all your #ifdef directives on
the top of all header files?
If you are using #import directive, did you have
checked for a miss of a redefinition macro?
If you did not create this project using ARX
Wizard, did you put the StdAfx.h DEBUG tags:
// Check if the build is DEBUG version and it's
intended
// to be used with Non-DEBUG AutoCAD.
// In this case, for MFC
header files, we need to undefine
// _DEBUG symbol
#if defined( _DEBUG)
&& !defined(DEBUG_THIS_APP_ONLY)
    #pragma
message("Building debug to be used with release AutoCAD")
#define DEBUG_THIS_APP_ONLY
    #undef
_DEBUG
#endif
#include <afxwin.h>
// Turn on the _DEBUG symbol if it was defined,
before including
// non-MFC header files.
#ifdef
DEBUG_THIS_APP_ONLY
    #define _DEBUG
#undef DEBUG_THIS_APP_ONLY
#endif
Let us know if you solve this issue...
Fernando.
Blade
the macro _ATL_MIN_CRT. This macro is defined so that you don't bring
the C Run-Time Library into your code if you don't need it.
choose the General category, then remove _ATL_MIN_CRT from the
Aragao
the ReleaseMinDependancy configuration - it gives me a redefinition. First
it was __free  and __malloc, then it was a redefinition of my
Interface (I am writing a COM server):
class
: error C2370: 'IID_ICurveX' : redefinition; different storage
class
'IID_ICurveX'
class
'CLSID_CurveX'
Generating Code...
Error executing
cl.exe.
warning(s)
to fix it?
Blade
size=2>
Guys, thank for all the help, there is an advance
on this case. But I didn't see anywhere what Fernando said. The build of
releaseMinSize gave the following
errors:Linking...MSVCRT.lib(dllsupp.obj) : error LNK2005:
__fltused already defined in StdAfx.objMSVCRT.lib(dllsupp.obj) : warning
LNK4006: __fltused already defined in StdAfx.obj; second definition
ignored   Creating library ReleaseMinSize/VBExtend3.lib and object
ReleaseMinSize/VBExtend3.expVBExtend3.exp : warning LNK4070:
/OUT:VBExtend3.DLL directive in .EXP differs from output filename
"ReleaseMinSize/VBExtend3.arx"; ignoring
directiveReleaseMinSize/VBExtend3.arx : fatal error LNK1169: one or more
multiply defined symbols foundError executing link.exe.I then
started to comment out everything one by one to see what caused the error,
and:// stdafx.cpp : source file that includes just the standard
includes// stdafx.pch will be the pre-compiled header// stdafx.obj will
contain the pre-compiled type information
#include "stdafx.h"
#if defined(_DEBUG) &&
!defined(_DEBUG_AUTOCAD)    #define
_DEBUG_WAS_DEFINED    #undef _DEBUG#endif
#ifdef
_ATL_STATIC_REGISTRY    #include
    #include
#endif
//#include
#include "acad15_i.c"#if
defined(_DEBUG_WAS_DEFINED)#undef _DEBUG_WAS_DEFINED#define
_DEBUG#endif
when I commented out this file (atlimpl.cpp) the
errors in ReleaseMinSize stopped. The problem is that I don't know that I did
when I commented out that line. Can you explain me the reason (I am a guy who
wants to know what he is doing when he does it, I want to uderstand it, not
just do it)? Here is the whole StdAfx.h:
// stdafx.h : include
file for standard system include files,// or project specific include files
that are used frequently,// but are changed infrequently#if
!defined(AFX_STDAFX_H__C8BC6D2F_9E91_46FC_823F_8201A2BE50F6__INCLUDED_)#define
#if _MSC_VER >= 1000#pragma
once#endif // _MSC_VER >= 1000
#define STRICT
#ifdef _DEBUG    #define
_ATL_DEBUG_QI    #define
_ATL_DEBUG_REFCOUNT#endif
#define _WIN32_WINNT 0x0400#define
_ATL_APARTMENT_THREADED
#include
//You may derive a class from CComModule
and use it if you want to override//something, but do not change the name of
_Module
extern CComModule _Module;
#include //#include "dbmain.h"//#include
"dbents.h"//#include "dbsymtb.h"//#include "dbobjptr.h"//#include
"rxdebug.h"//#include "acdb.h" // acdb definitions#include
"rxregsvc.h" // ARX
linker#include "dbapserv.h" // Host application services#include "aced.h"
// aced stuff//#include
"adslib.h" // RXADS definitions//#include "rxmfcapi.h" // ObjectARX MFC
support//#include "AcExtensionModule.h" // Utility class for extension
dlls#include "dbptrar.h" // void pointer array #include "acad15.h"
// AutoCAD Automation
interfaces#include "axlock.h" // Document locking class (no operation in
ObjectDBX)//#include "oleaprot.h"//#include
"acutmem.h"#include // Added by ClassView#if
_DEBUG#endif//{{AFX_INSERT_LOCATION}}// Microsoft Visual C++ will insert
additional declarations immediately before the previous line.#endif
!defined(AFX_STDAFX_H__C8BC6D2F_9E91_46FC_823F_8201A2BE50F6__INCLUDED)
I hope this will help, and I hope you'll explain me wny
this (edited) happens so it won't happen anymore. I am a begginer and don't have any
books. I am learning from the MSDN Library and the ObjectARX SDK so I have a lot
fo misses. There is no books for COM or ObjectARX in my country so I am relying
only on you. I have NOONE else to ask. So I am VERY GRATEFUL for any help I
get.
Thank you all.
Blade
