Recover files from ObjectARX app
I want to recover several files from an ObjectARX app.
I have studied an earlier topic: http://discussion.autodesk.com/thread.jspa?messageID=5255836
which seems to deal with the problem.
But compiling the code:
// by Fenton Webb, DevTech, Autodesk
// my timer proc, this will pump the recover command when Autocad is ready
void CALLBACK EXPORT RecoverTimer (HWND hWnd, UINT nMsg, UINT nIDEvent, DWORD dwTime)
CString cmd = _T("c:\\temp\\test.dwg\n");
// RegisterAPP() ;
COPYDATASTRUCT cmdMsg;
HWND hWndACAD;
hWndACAD = adsw_acadMainWnd();
cmdMsg.dwData = (DWORD)1;
cmdMsg.cbData = (DWORD)_tcslen(cmd) + 1;
cmdMsg.lpData = cmd.GetBuffer(cmd.GetLength()+1);
// Send the message to AutoCAD.
SendMessage(hWndACAD, WM_COPYDATA, (WPARAM)hWndACAD, (LPARAM)&cmdMsg);
acedGetAcadFrame()->KillTimer(nIDEvent);
void CFileRecovery::OpenDwgFromApplicationContext(void *pData)
if(acDocManager->isApplicationContext())
CString *dwgNameToOpen = reinterpret_cast(pData);
acDocManager->sendStringToExecute(curDoc(), _T("recover "));
//acDocManager->appContextOpenDocument(*dwgNameToOpen);
acedGetAcadFrame()->SetTimer(999, 1000, RecoverTimer);
else return;
acDocManager->setCurDocument(acDocManager->mdiActiveDocument());
// This is command 'OPENDWGDOC, by Fenton Webb [29/08/2003], DevTech, Autodesk
void CFileRecovery::asdkopendwgDoc()
CString dwgNameToOpen;
dwgNameToOpen = _T("c:\\temp\\test.dwg\n") ;
acDocManager->appContextOpenDocument(dwgNameToOpen);
else acDocManager->executeInApplicationContext(CFileRecovery::OpenDwgFromApplicationContext, &dwgNameToOpen);
Result in the following compiler error:
error C3867: 'CFileRecovery::OpenDwgFromApplicationContext': function call missing argument list; use '&CFileRecovery::OpenDwgFromApplicationContext' to create a pointer to member
Does anyone have an idea of what I am missing?
Johannes P. Hansen
The error message tells you the problem and how to fix it (add the '&'
prefix). You'll also need to change the two instances of "+ 1" to "+
sizeof(TCHAR)" in the RecoverTimer function. 🙂
Owen Wengerd
President, ManuSoft <>
VP Americas, CADLock, Inc. <>
Thanks Owen,
I tried the "&" one too, but that didn't help much :o((
I changed the code to:
else acDocManager->executeInApplicationContext(&CFileRecovery::OpenDwgFromApplicationContext, &dwgNameToOpen);
and got the error:
error C2664: 'AcApDocManager::executeInApplicationContext' : cannot convert parameter 1 from 'void (__thiscall CFileRecovery::* )(void *)' to 'void (__cdecl *)(void *)'
By "You'll also need to change the two instances of "+ 1" to "+
sizeof(TCHAR)" in the RecoverTimer function. " do you mean this:
cmdMsg.cbData = (DWORD)_tcslen(cmd)+ sizeof(TCHAR);
cmdMsg.lpData = cmd.GetBuffer(cmd.GetLength()+ sizeof(TCHAR));
Kind regards
Johannes P. Hansen
Johannes:
> ...cannot convert parameter 1 from 'void (__thiscall
> CFileRecovery::* )(void *)'...
CFileRecovery::OpenDwgFromApplicationContext must be declared as a static
function, and correct on the "+ 1" bug. 🙂
Owen Wengerd
Thanks again Owen,
Great - I am getting closer :o))
I'm able to compile and get the app running.
Problem is that the recover dialog box pops up :o((
I'm not quite sure if I got corrected the "+1" bug in the right manner.
How would you type the code?
Kind regards
Johannes P. Hansen
Hi Owen,
I almost got the app running now and everything seem to work, when I set FILEDIA to 0.
Last problem is that I get an annoying Autocad Messagebox telling me that Audit accepted recovered database.
I tried to send an other message just containing a CR - but that didn't help.
Do You have any idea how to get rid of the messagebox?
Kind regards
Johannes P. Hansen
