"Command in progress" after save as
I am facing a problem during saving file in AutoCAD (2013 / 2014) using "Save As" menu.
Our software is AutoCAD based and we allow user to work with many drawings in single session.
If I change one drawing file and click "Save As" then it saves file with new name at different location.
However later when I try to perform some other action in same or different drawing, then getting following message -
                document "....dwg" has a command in progress.
                Hit enter to cancel or [Retry]
Hitting enter or retry does not help and I need to kill AutoCAD exe and then restart it for further work.
Such problem is not observed if I save the drawing, on save prompt while closing the drawing.
Also, this problem is observed when "FIBERWORLD" is "1" and not when it has value as "0".
Please reply -
If you resolved such issue by fixing code, if yes then how?
Or
If this is the problem from AutoCAD side.
Thanks a lot for your time.
With regards
ND
StephenPreston
It sounds like you locked a document and didn't dispose of your documentlock when you'd finished.
Cheers,
Stephen Preston
Autodesk Developer Network
Thanks for you hint...
In our code, "acDocManagerPtr()->lockDocument(..)" & "acDocManagerPtr()->unlockDocument(..);" is called in many methods.
Went through each sequence of lock & unlock call.
In 1 method, found that only "acDocManagerPtr()->lockDocument(..)" is called and respective "unlock" is not written there.
So updated code and added "acDocManagerPtr()->unlockDocument(..);" there.
This fix has resolved our problem.
Thanks again for your reply.
with regards
ND.
Alexander.Rivilis
There is a class AcAxDocLock which can help you. Its constructor lock document and destructor unlock document.
For example:
  AcAxDocLock docLock;
  // Now current document is locked
// Now current document is unlocked
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
