Problem with AcgeMatrix3d?
D_D_K
D_D_K
hello I am using vsto2019(compile platform vsto2017), however I cannot use the AcGeMatrix3d class, I always get errors when compiling the code. This is the code I use
//register function test
static void scaleEntity(); extern void test() { scaleEntitye(); } //Try compiling the code static void scaleEntity() { ADSN adent; acdbEntLast(adent); ID is = IDNULL; acdbGetObjectId(is, adent); AcDbObjectIdArray mas; mas.append(is); ads_point pPoint; double scaleCoef = 2.0; AcGeMatrix3d m; m.setToScaling(scaleCoef, AcGePoint3d(pPoint[X], pPoint[Y], pPoint[Z])); //continue code
This is the error I receive,
Error	LNK2019	unresolved external symbol "public: class AcGeMatrix3d & __cdecl AcGeMatrix3d::setToScaling(double,class AcGePoint3d const &)" (?setToScaling@AcGeMatrix3d@@QEAAAEAV1@NAEBVAcGePoint3d@@@Z) referenced in function "void __cdecl scaleEntitye(void)" (?scaleEntitye@@YAXXZ)
Error	LNK2019	unresolved external symbol "public: __cdecl AcGeMatrix3d::AcGeMatrix3d(void)" (??0AcGeMatrix3d@@QEAA@XZ) referenced in function "void __cdecl scaleEntitye(void)" (?scaleEntitye@@YAXXZ)
If I didn't declare the prototype code static void scaleEntity () and call another function or call scaleEntity but remove these code related AcGeMatrix3d
	AcGeMatrix3d m;
then the code compiles normally.
I tried changing the runtime library in properties but it still didn't work.
Please help, thanks a lot!
Alexander.Rivilis
You have to link with acge23.lib (23 - for AutoCAD 2019...2020).
Edited as @moogalm corrected
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
moogalm
Autodesk Support
Autodesk Support
AcGe24.lib is not for AutoCAD 2020, AutoCAD 2020 is non binary breaking release, find for AcGe23.lib from SDK\lib-x64.
Alexander.Rivilis
Oops! Sorry. I think you can guess in what version of ObjectARX SDK I looked. 🙂
Expert Elite Member
D_D_K
Hi Experts , It was really working 😀 , i am now able to continue with my project.
Many thanks!
