Plot API questions.
Plot API questions.
William_Gonzales_Sanchez
Plot API questions.
Hello all,
I have a program based on the AsdkPlotAPI example. It works fine but I would like to improve these 2 points:
1) It creates another AutoCAD instance to perform the plot job. How to avoid it? How to use the current AutoCAD instance?
2) It is slow compared with the PLOT command.
I suposed this ARX Plot API is the same used by the PLOT command. I am using AutoCAD 2008.
Thanks in advance.
William GS
I know it's an old topic, but I just dealt with it myself and I hope it can be of use to anyone, as I didn't find any mention of it in the documentation.
I started replacing the old hackish COM-based plot code with the new Plot API, and found out the same using code based on the sample - plotting a simple layout to PDF takes about 25 seconds on my laptop, during which time a second acad.exe instance is launched, and for most of the time it seems to be doing nothing.
The cause seems to be the BACKGROUNDPLOT system variable, as soon as I disabled background plotting, I had the PDF file done in a about a second, wtihout changin anything in the code.
